Carb Problem
Old Jun 27, 2007 | 10:43 PM
  #31
FordF100man's Avatar
FordF100man
yea i will try it out tomorrow and find out if they open or not.
Old Jul 2, 2007 | 09:35 PM
  #32
FordF100man
I have another question about my carb it has been sitting for a couple of days and i see that the gasket between the carb and intake is wet, and driped down a little bit. What could be wrong with it. And i just replaced the gasket and rebuilt the carb.
Old Jul 3, 2007 | 10:18 AM
  #33
arctic y block's Avatar
arctic y block
float level to high?
Old Jul 3, 2007 | 11:22 AM
  #34
PROSTOCK's Avatar
PROSTOCK
Lots of times on Holley's the accel diaphram will leak because the pump cover has been overtightened, warped and the will not seal properly to the bottom of the bowl. Terrible design if you ask me. This can be improved by removing said cover and filing it back flat, but I have never had a completely leak free Holley. I have also had to mill flat both ends of the main body where the metering body/plate and bowls attach. Same goes for the throttle plate and respective mating surface. There are lots(too many) places for Holley's to leak.
Old Jul 3, 2007 | 12:29 PM
  #35
arctic y block
Yes. Kinda like a Harley, If it don't leak somewhere than it prolly don't run.
Old Jul 3, 2007 | 09:37 PM
  #36
FordF100man
Yea i have been checking things over so hopefully i find what is wrong with it.
whisler
64
Feb 6, 2017 04:51 PM
bigfoot22
Jun 11, 2016 09:05 PM
chiefsfootball
39
Jun 4, 2015 06:12 AM
1951flatheaddave
25
May 2, 2012 12:49 PM
sams123
Apr 9, 2012 10:04 PM
