33's stock?
Old Jun 23, 2007 | 08:49 PM
Judson4.9L's Avatar
Judson4.9L
33's stock?
My truck has 33x12.50s with plenty of clearance in the front and rear. They were on it when I purchased it but I cant tell if their is a lift. I did not expect that much clearance being stock. It could use a leveling kit but there is alot of clearance. Is my truck lifted a little? There is not a body lift and no blocks under the leafs...
1990 F150 4x4 5 Speed Manual
Old Jun 23, 2007 | 09:06 PM
msb71's Avatar
msb71
There may have been a add-a-leaf installed or 2, how many leaf springs are in the pack?
Mike
Old Jun 23, 2007 | 09:12 PM
Judson4.9L's Avatar
Judson4.9L
Mike
There are four in the pack.
Old Jun 23, 2007 | 09:19 PM
lostin90s's Avatar
lostin90s
Could have and older 2-3" lift on it . AS the 33" tire would fit but would be not much clearance around them.
They could have put 2" lift coils and had springs re arched. ?? Good question
Old Jun 23, 2007 | 10:09 PM
msb71's Avatar
msb71
Do the tires rub on the inner fender? always thought 32's were the largest stock size tire you could put on a truck without lifting it.
Mike
Old Jun 23, 2007 | 10:24 PM
Judson4.9L's Avatar
Judson4.9L
They dont rub unless I REALLY crank the wheel hard. I have a pretty good turn radius.
Old Jun 23, 2007 | 10:43 PM
Dean88's Avatar
Dean88
You might have a stock suspension, I have 35" in the back and 32" in the front, and it looks to me that 33" would fit pretty easy in the front.
adam.hilberath
13
May 3, 2012 09:48 PM
Lead_Pusher
Jan 28, 2009 03:11 PM
F250Growler
13
Jul 22, 2008 10:19 PM
Broke_Okie
Offroad & 4x4
Jan 25, 2006 08:05 PM
92Custom
Apr 16, 2002 06:56 PM
