Sponsored by: Real Truck
Stupid Mirror Question
Old Jun 20, 2007 | 08:07 PM
jmombo1321's Avatar
jmombo1321
Here's a stupid question about mirrors, so before I break something I figure I should ask it, how do you get the mirror(whole housing and everything) off of the truck...I wanna switch from factory stock to the telescopic tow mirrors, but can't seem to pop the housing(interior) off to expose bolts.
Old Jun 20, 2007 | 08:18 PM
Biggziff's Avatar
Biggziff
On my 05 I just pulled the plastic cover off on the inside.
Old Jun 20, 2007 | 08:22 PM
kzzchicago's Avatar
kzzchicago
Squeese the black plastic triangle cap, it has a few tabs on it so be careful not to break them, at least thats whats on my 99 f250, and 99 f350.
Be careful and go easy.
Old Jun 20, 2007 | 08:43 PM
Muellermw12's Avatar
Muellermw12
mirrors
hey i have those stupid stock mirrors too. Anyone know a good place to buy them? and if i have no lights on the stock can i put mirrors with lights on them without running new wires? 01 F250
Old Jun 20, 2007 | 09:20 PM
dfuser's Avatar
dfuser
You may want to consider the 08 mirrors. They are a direct bolt on and you just need to connect the wires. We provide the wire diagram and new connectors.
http://www.dfuser.com/catalog/2008-f...7-f250f450.php
You do need to run wire for the additional Lights.
Bill
Old Jun 21, 2007 | 08:34 AM
Biggziff's Avatar
Biggziff
http://www.dfuser.com/catalog/2008-ford-superduty-towing-mirror-retrofit-kit-992007-f250f450.php
Bill
Bill:
You don't mention the left/right adjust issue on your website. Have you figured out a way around that with the 08 mirrors?
Thanks
Old Jun 21, 2007 | 09:33 AM
msgtg's Avatar
msgtg
I have the extendable towing mirrors. To get the covers off, run the mirror all the way to the right and up and down to reach the tabs.
BE CAREFUL! I broke the first tab off not realizing that I didn't have to go-rilla the thing off.
Old Jun 21, 2007 | 12:21 PM
Beerstalker's Avatar
Beerstalker
msgtg, I think he wants to remove the whole mirror, not just the mirro back/light.
Like Biggziff said, the black triangle shape at the front of the window in the inside of the truck will just pull straight off the door. It takes a little force, but not too much. Some of the bolts are hiding under rubber caps, and some are hiding under the foam sound deadening/moisture barrier stuff.
Old Jun 21, 2007 | 05:40 PM
dfuser's Avatar
dfuser
Originally Posted by Biggziff
Bill:
Thanks
Have not really figured that out. The only way to do it is figure how to add the 08 switch in.
soupy1957
2009 - 2014 F150
Jan 4, 2014 03:46 PM
pimpedrsrage
6.4L Power Stroke Diesel
Nov 28, 2013 12:07 PM
birdnut
Feb 1, 2013 06:50 AM
jack_pine
6.7L Power Stroke Diesel
Jun 5, 2012 05:36 PM
