Sponsored by: Auxito
rear rotors??
Old Jun 18, 2007 | 06:17 PM
stigedis's Avatar
stigedis
rear rotors??
I was told by the mechanic at the dealer that i needed new rear rotors, due to a rotational noise i have after they replaced the rear axle seal. Said I never heard it because it was packed full of grease. Now that the seal is fixed and rotor is clean, its making a new noise that disappears when i apply the brake. They assured me it was not a wheel bearing as i suspected.
they want $80 a rotor and hour shop time to replace.
I called NAPA...they have them in stock. But they needed to know if i had 12 0r 14mm wheel studs. What are they asking for? just the length? can this be determined thru vin or something or do i have to take the wheel off measure the length and put wheel back on and goto NAPA???
Thanks in advance...
mks
Old Jun 18, 2007 | 06:24 PM
scottie2hottie's Avatar
scottie2hottie
The rotors on this truck are expensive all around, so I do not doubt that that is a fair price for them....I'm not 100% where the difference is in the wheel stud sizes, but I am one to assume it's the trucks that come factory with bigger wheels/engines (lightnings/harleys) My is a run of the mill 01 v6 5 spd it has the 12mm studs. the rotors were abouts $70 a piece for the rears at AZ
Old Jun 18, 2007 | 06:49 PM
rsylvstr's Avatar
rsylvstr
uhhhh, what truck???
Old Jun 18, 2007 | 08:23 PM
scottie2hottie
LOL i was assuming by the forum it's a 97-03 F150. But you're absolutely right, more details is a must.
Old Jun 18, 2007 | 08:43 PM
galaxie641's Avatar
galaxie641
I am 95% sure you have 14mm, since you have rear discs which were only on trucks from '99 which is the same year they went to 14mm studs, but I have seen some disagreement of when in '99 they switched. 14mm is the diameter BTW. So if you have a '00 or newer I guarantee they are 14mm.
Old Jun 18, 2007 | 08:48 PM
rsylvstr's Avatar
rsylvstr
correct...I know mine are 14mm
Old Jun 18, 2007 | 09:06 PM
stigedis's Avatar
stigedis
ahhh. i should have stated it is a 2000 F-150 4X4 5.4L
I guess since i already got the 12 mm that I will have to take them back....bummer.
Old Jun 18, 2007 | 09:31 PM
rsylvstr's Avatar
rsylvstr
just try them on one stud, if they don't fit, you know you have 14's
Old Jun 18, 2007 | 10:17 PM
stigedis's Avatar
stigedis
thats my plan. thanks for all the input.....
stig
Old Jun 19, 2007 | 07:06 AM
scottie2hottie
Just cause it has rear discs don't mean it has 14mm studs. Mine has is '01 with rear discs and has 12mm studs.
Old Jun 19, 2007 | 07:46 PM
stigedis's Avatar
stigedis
and so I am unable to determine how to get the rear rotor off this 2000 F150>>\
Do you need special tools? How the heck do you go about taking off the caliper to get at the rotor???
thanks
Old Jun 19, 2007 | 08:48 PM
stigedis's Avatar
stigedis
figured it out...simple...just gotta sit back and look at it...
rotor came off easily too.
thanks,,,
stemwill
Nov 8, 2011 08:54 PM
Ex Factor
Mar 29, 2011 07:06 AM
mich800
Nov 5, 2010 10:24 AM
azzy522
Sep 23, 2010 12:18 PM
mtondreo
15
Oct 21, 2009 04:55 PM
