Brake controler question
Old Jun 20, 2007 | 09:54 PM
aklim's Avatar
aklim
You need the fuse in place to power the system. That is in the fuse box in the engine bay
Old Jun 22, 2007 | 11:58 PM
Stewart_H's Avatar
Stewart_H
Originally Posted by aklim
Since Andrew's picture is a broken link, here is the picture he was posting. He was nice enough to take the picture for some blind doofus who couldn't find the plug when it was staring him in the face. (yeah, I was the blind doofus)
The light grey plug is the OEM harness. The brown plug is the pigtail from the brake controller. In this case, a Tekonsha Prodigy unit.
Stewart
Old Jul 8, 2007 | 11:28 AM
jjbirish's Avatar
jjbirish
Stewart
maybe i am the blind doofus. what picture, i don't see it.
but thanks for tryin
Old Jul 8, 2007 | 11:36 AM
jjbirish's Avatar
jjbirish
Originally Posted by Brians97F250Crew
The wires you found are just pass through wires provided by the factory so you can wire something up through the firewall.
Take your fuse panel cover off, look to the right side through the triangle opening. That is the plug there where you need to plug in your brake controller. It is prewired to the big plug in the rear. Mine was plug and play no other fuses or relays needed.
thank you for the picture. i would have never found it without it.
yours looks angled a little bit for easier access than mine, but i finally got it.
is it ok if i keep and use the picture for referance if someone else should ask?
jeepclark
Feb 25, 2012 03:14 PM
jeeplj8
Jul 1, 2011 06:11 PM
Frankievespa
Apr 11, 2011 09:56 PM
dogzpaws
All Things Towing
Aug 31, 2007 11:02 PM
nowakr
Sep 20, 2006 04:31 PM
