Help with new halogen headlights?
Old May 11, 2016 | 12:02 AM
comsupany's Avatar
comsupany
I want to improve the appearance of my truck and I am interested in the following headlights. In the description it says the following:
Technical Tips: For Cars That Do Not Have Daytime Running Light ( DRL ) Function: The Lights / HALO / LED Part Can Serve As / Give Out Daytime Running Light ( DRL ) As Extra Functions But In Order For It to Work, You Might Need Modifications To The Wirings And Plugs. Additional Wirings & Plugs For Daytime Running Light ( DRL ) Function Will Not Be Provided.
Is there someone here that might know what kind of modifications I might need? It says no manual is included. Here's the url:
Chrome LED 2 Halo Rims Projector Head Lights Corner Signal 99 04 F250 Excursion | eBay
Old May 11, 2016 | 01:27 PM
Gatordog's Avatar
Gatordog
My truck has those, previous owner installed. I hate them, the mounts are off so they are zip tied in place. Also they mess with the radio.
Old May 11, 2016 | 02:48 PM
comsupany's Avatar
comsupany
Thanks for the heads up! I found these and they say it's an OE replaement so it's plug and play!
Spec-D® 2LHP-F25099-TM - Ford F-450 with Factory Sealed Beam Headlights 2002 Chrome Dual Halo Projector LED Headlights
Old May 11, 2016 | 04:25 PM
Supercab's Avatar
Supercab
Wink
Is your truck an XL version with the GLASS sealed beam headlights now?
If so, you might want to ask who else has done the swap to the plastic housings with bulbs in them.
That said, IMO what you're looking at is pure ricer, not becoming to trucks like ours.
If I might make a suggestion just get a decent set of (aftermarket)?? or OEM '02-'04 headlights and the matching "clear" corners, much better look, MUCH better light output than stock '00 plastic housings...
Let us know what you've got now.....
Old May 13, 2016 | 08:06 PM
comsupany's Avatar
comsupany
I didn't see this response until this afternoon. I ordered new headlights and new a new grill today so I guess I'll see how they look. They said they will provide support and they are a OE replacement. Below are the parts I ordered and also a picture of my current headlight. I agree that they might not look right but sometimes it's hard to tell unless you "try it on". The rims will make a big difference I think.
Sinister Diesel® MKM-MOD-CR - Ford F-450 Super Duty 2002 Chrome Grille
Old May 13, 2016 | 08:29 PM
Supercab's Avatar
Supercab
Gotcha, No problem, the ones you ordered may work for you.......
They absolutely WILL fit your truck and be a direct replacement.
Looks like they have some LEDs as accents around the edges.......these must be wired to your parking lights I believe-A friend installed this type in a '99 F150 and they looked so ricer (sorry) and the LEDs stopped working within a month......
The grill is good, I had one on MY '99 F350 before I did the complete front facelift to full '07 specs......
Please post pictures when you've got the new lights and grille installed......
Old May 13, 2016 | 11:38 PM
JTC19's Avatar
JTC19
just wire the LEDs to your parking lights, although they will look off on a big ford truck. Thats just my opinion though, and you know what people say about opinions . . .
Old May 14, 2016 | 12:16 AM
comsupany's Avatar
comsupany
What other parts can I use to modernize looks? I was going to post a before and after, after some upgrades but here is the before now (the picture is with the grill off and the hood open).
Old May 14, 2016 | 05:19 AM
Supercab's Avatar
Supercab
Uh, may be a new front bumper? '08 up mirrors? How about the simulators??
Old May 14, 2016 | 02:37 PM
comsupany's Avatar
comsupany
definitly simulators, that and new tires will make it look a lot better. I've never see '08 mirrors? Can you link to some '08 mirrors?. I'm planning a new bumper too, soon.
Old May 14, 2016 | 03:33 PM
Supercab's Avatar
Supercab
Heres ONE listing for the '08-'15 mirrors.
08 16 Ford F250 Super Duty Towing Power Heated Mirrors Turn Signal Pair Set Side | eBay
Please note IF your current mirrors are POWER there is an adaptor harness that will plug in JUST the power for the mirrors, IF you want the clearance lights and signals to work you'll have to wire them.
Lots of nay-sayers on aftermarket mirrors, some are good, some good, some bad, There are also MANUAL versions available.
I put OEM (take-offs) ('14) on MY L99 F350, I hooked up the clearance lights, signals, and have the rough wiring done for the heat which I'll do later....
Do some investigation for yourself before purchase.
(I HATE rattling mirrors)
Old May 15, 2016 | 07:00 PM
Bonanza35's Avatar
Bonanza35
Like to see the pictures when your done. Is that grill billet? I'd like to do that on my 99 CC.
Old May 15, 2016 | 08:09 PM
comsupany's Avatar
comsupany
I will! If you mean the picture I posted, that's the radiator. I had taken the grill off (orig I was going to paint it but decided the end result wasn't what I was looking for).
Old May 15, 2016 | 11:28 PM
Bonanza35's Avatar
Bonanza35
No the link you supplied to where you were buying your grill and lights.
Old May 16, 2016 | 12:56 AM
comsupany's Avatar
comsupany
I understand the billet grilles to be with horizontal lines. The salesman said it was not that type of grille it has a honeycomb pattern (which I think I'll prefer).
curtis73
Mar 10, 2012 10:10 PM
Turbodogg
2009 - 2014 F150
Jan 11, 2012 04:03 PM
blakeusa
Sep 20, 2011 10:36 PM
mikebrawn1
Jul 8, 2010 06:29 AM
GR$$N$
Feb 2, 2009 04:23 PM
