How set the push button Keyless entry
Old Jun 13, 2007 | 03:58 PM
SilverSTX's Avatar
SilverSTX
I just got a 2007 f-150 with the keypad under the door handle, and after reading in the manual I am still unsure how to set this. Any help is appreciated.
Old Jun 13, 2007 | 04:23 PM
FHBrian's Avatar
FHBrian
Do you have the original code that was assigned to the Truck? It will be on a card in the binder with the manuals and stuff. I bought mine used and found it in between some pages of the manual. If you do not have the original code you can get it from the dealer by them running a scan on it, but they will probably charge you or it is behind the seat on a box back there. The original factory code has to stay and you can set one personal code I believe. But w/o that factory code you won't be able to do anything.
Old Jun 13, 2007 | 05:06 PM
thechief96's Avatar
thechief96
I set mine and you can only have one personal code at a time and you need the original to set it. I t is on a card in your owers manual set of books.
Old Jun 13, 2007 | 06:41 PM
ech0sh4y's Avatar
ech0sh4y
Somone wrote on a business card the code... but i can't seem to get it to work either.. migth be the wrong code I can't find the original card so i suppose i have to rip the back seat apart is this a PITA?
Old Jun 13, 2007 | 08:28 PM
FHBrian's Avatar
FHBrian
If you don't want to mess with that you may check w/ a dealership or the dealer you bought it from and see what they would charge you. Might be easier and quicker than messing with the other. But I guess it also depends on what your time is worth to you.
Old Jun 14, 2007 | 01:12 AM
blams2004's Avatar
blams2004
If you say the code on the business card is not working either, then I would go to the dealer. If the one they gave you is not working or not the correct number they should do a scan and get the correct number or fix it for you.
Old Jun 14, 2007 | 06:48 AM
SilverSTX's Avatar
SilverSTX
Thanks I will have to look for the card for the number
Old Feb 9, 2008 | 10:33 AM
grizzws's Avatar
grizzws
Look Under the dash behind the radio, it might be behind the insulation, Voila?
SuperDuty93
18
Feb 22, 2013 01:27 AM
lakedweller
6.7L Power Stroke Diesel
148
Jul 16, 2012 04:24 PM
justin_brandstein
Mar 26, 2009 02:39 AM
17fordguy
Oct 22, 2007 10:16 PM
papa's 64
1983 - 2012 Ranger & B-Series
15
Feb 25, 2007 10:25 PM
