Sponsored by: Real Truck
4wd Check
Old Jun 13, 2007 | 03:08 PM
Storm's Avatar
Storm
4wd Check
I drew a blank.. Need two confirmations please..
1. Auto Hubs, Counter Clockwise is Auto, Clockwise is Lock right?
2. If hubs are stuck locked regardless of position, the U-Joint and Front Driveshaft will rotate correct?
Old Jun 13, 2007 | 03:45 PM
jvoigt's Avatar
jvoigt
Yes, Clockwise= "Lock" and Counter Clockwise="Auto"
When I turn my front axel when the hubs are in "Auto it turns the axel to the t-case.....um but I dont know if that is how they are supposed to work.
Old Jun 13, 2007 | 03:49 PM
jvoigt's Avatar
jvoigt
On second thought, um if your hubs are "frozen", and if one or both are locked you should not be able to get much rotation out of the shafts.
Old Jun 13, 2007 | 03:57 PM
Storm's Avatar
Storm
Hmm.. Not mine..
I was with TNT today for lunch and we were talking bout hubs.. I'm yanking mine for Warn.. But he has the auto's.. I was checking his ***** and they are EXTREMELY tight to turn.. They were turned clockwise into Locked.. I checked his Knuckle and his Shaft.. Either position and it turns.. I thought that the Knuckles were disconnected when the hub wasn't locked?
Old Jun 13, 2007 | 04:10 PM
jvoigt's Avatar
jvoigt
Well I keep my truck in "Auto" all the time but every once in a while I turn the hubs to lock and then back to auto just too prevent my hubs from getting hard to turn. Anyways When I turn the axle near the hub it turns freely on both sides and also turns the t-case axle too, Now isnt that the way it works until you lock your hubs and then you shouldnt get any movement from the front axel right?
Old Jun 13, 2007 | 04:24 PM
redford's Avatar
redford
FTE Leadership Emeritus
If the hubs are locked (and the wheel is not off the ground) you should not be able to turn the axle shaft/steering knuckle. It should be locked to the wheel.
Old Jun 13, 2007 | 04:35 PM
krewat's Avatar
krewat
Clockwise to lock, counter-clockwise for Auto.
With both sides in Auto (and the ESOF **** in 4x2), you should be able to turn the driveshaft and axles.
Do this, in this order:
1) Turn both front hubs to LOCK.
2) Try to turn the front driveshaft by hand. If it moves, one of your hubs isn't locking - while spinning the driveshaft, if should be obvious which axle is turning, that's your bad hub.
3) Turn both front hubs to AUTO/UNLOCK.
4) Spin driveshaft again. It should spin freely. HOWEVER - also check that BOTH axles are spinning freely too. The driveshaft can spin free with only one hub unlocked.
The above assumes that the transfer case is not stuck in 4x4
When you turn the hubs to AUTO/UNLOCK, and you seem to have a hub that's still locked, it could be the axle stub locking up inside the "inner spindle bearing" - the needle bearing inside the wheel bearing where the axle stub rides.
Old Jun 13, 2007 | 04:49 PM
Storm's Avatar
Storm
Thanks guys... Just what I needed to hear.. I'll let TNT know and we'll do some more checking.. His hubs were turned Clockwise when I checked them.. Said its been like that for months.. So I'm thinking his needle bearings may be shot now and his front end is actually locked..
I think my drivers side is the same but I have manual hubs..
mich800
6.4L Power Stroke Diesel
15
Aug 22, 2014 07:45 AM
Reckless
Aug 6, 2014 09:55 PM
buck_
Jul 16, 2011 08:14 AM
arhuranna
May 21, 2009 02:44 PM
