I have a 2001 V-10 4x4 that I have a question on the locking hub position. This is my first Ford and my first anything with locking hubs. In the manual it shows the hubs being turned clockwise to the auto hub mark. Mine have no marks that I can find but they are turned clockwise. Is this the correct position for everyday driving?
Yes ,when you look on the drawing the LOCK position is on the left and AUTO is on the right.But there's a position "dot"to where you have to move the **** to get LOCK or AUTO.So if you want to get to LOCK you go right,and AUTO you turn left.
Bit confusing looking on the drawing I agree.
After doing some research I agree with ZBIGBIG19TH because it is confusing. The manual is 1/2 right because it has the 2 captions switched above the drawing. (See my link here).
If you really get stuck jack up one wheel and spin it if you see the axle and U joint behind the hub turning you are locked. Other option is just to try turning the U joint by hand with the wheel on the ground it will not turn if the hub is locked
