Sponsored by: Real Truck
Front axle Ujoint replacement
Old Jul 14, 2011 | 08:19 AM
buck_'s Avatar
buck_
My Dad's 03' F250's U-joints are shot. Is there any difference in taking the front axle apart to replace the U-joints between his truck and my 89' F-350?
I replaced his lock out hubs some time ago and they were very different then mine, so I'm wondering if there are any other differences or are the D-60s more or less the same?
Thanks
Buck
Old Jul 15, 2011 | 12:44 AM
buck_'s Avatar
buck_
Anyone have an answer to my question?
Old Jul 15, 2011 | 04:40 AM
ak-angler's Avatar
ak-angler
I haven't taken the front end apart on the older Fords, but I have done the bearings/ball joints/axle joints on my 2003. You have to pull the front axles to R&R the ball joints. So, you might want to check out this write-up for replacing the ball joints on a Super Duty. Just stop short of actually removing the knuckle/ball joints. Then, once you have the axles out, just press the old u-joints out, press the new ones back in, and follow the write-up for re-installing everything. There's a couple special tools you'll need to have, along with new knuckle seals. I hope that helps.
Old Jul 15, 2011 | 09:38 AM
1975StroppeBaja's Avatar
1975StroppeBaja
The SD front end will be quite a bit different than the older front ends. I've never worked on a '89 D60 so I can't say for sure but if its anything like the D44's then the SD will be different.
You'll have to remove the unit bearing assy to get the axle out.
Then, you'll have to deal with the big knuckle seal on the axle. You'll probably want to replace that seal while you're in there and its a bit pricy (~$50) and requires a special driver to install it & to install the axle afterward.
I put up some info and pics here: 2004 F250 Ball Joint Replacement
Old Jul 16, 2011 | 03:09 AM
buck_'s Avatar
buck_
Great write up. Thank you, thank you, thank you! Just what I was looking for.
Just for FYI, the D-44 and D-60 (old) are a lot alike in the way they are put together. From the pics you have the new D-60 is completely different.
Thanks again
Old Jul 16, 2011 | 08:14 AM
1975StroppeBaja
You're welcome!
Good luck with the u-joints!
greentruck72
19
Aug 2, 2016 10:38 AM
corksil
Sep 13, 2015 08:06 PM
Budman1962
Aug 30, 2015 09:50 AM
Tailgate55
Jan 16, 2014 07:02 PM
f250red
May 8, 2010 05:03 AM
