help with obd codes
Old Jun 13, 2007 | 08:05 AM
Action4478's Avatar
Action4478
would this cause the 1211 code
How bad is it leaking?...
Old Jun 13, 2007 | 11:53 AM
bigbadwolfe's Avatar
bigbadwolfe
it leaks pretty good
Old Jun 13, 2007 | 04:01 PM
Action4478's Avatar
Action4478
It could cause 1211 , usually it because the HPOP can't keep up or fuel pressure at WOT.....
Old Jun 13, 2007 | 04:12 PM
bigbadwolfe
i get it at idle
Old Jun 13, 2007 | 04:29 PM
Action4478's Avatar
Action4478
This is From the shop manual...
KE7 KOER ON-DEMAND DIAGNOSTIC TROUBLE CODE (DTC) P1211
  • DTC P1211 indicates that injection control pressure was above or below commanded desired pressure during self test mode.
  • Possible causes:
    • incorrect oil or viscosity
    • poor oil quality
    • gel fuel/no fuel
    • low fuel pressure
    • damaged IPR valve
    • high-pressure oil system leak
    • damaged high-pressure oil pump
    • damaged PCM
  • Verify correct oil quality/viscosity and correct fuel grade are being used for the temperature conditions.
Is oil and fuel quality OK?
You get code 1211 at idle?...I've never heard of that before....
Old Jun 13, 2007 | 06:51 PM
bigbadwolfe
i just changed oil yesterday fule filter under a month i also rebuilt the ipr a week ago i am thinking that the leak i have on the rear pass side oil galley or the hpop is the cause of all this what do you think
Old Jun 13, 2007 | 07:06 PM
Action4478's Avatar
Action4478
Regardless. the leak needs to be fixed,, we'll see after that.....
Old Jun 13, 2007 | 07:09 PM
bigbadwolfe
i tried today but that stupid stock down pipe is in the way so i must get a new down pipe and fix the leak at the same time
Old Jun 13, 2007 | 07:13 PM
Action4478's Avatar
Action4478
It sounds like an opportunity.....
Old Jun 13, 2007 | 07:32 PM
bigbadwolfe
yeh an opportunity to put a real downpipe in and fix the leak
Tile man
2004 - 2008 F150
Apr 18, 2017 08:51 PM
Whitey Ford
Mar 23, 2016 03:59 PM
Long bed ford
2004 - 2008 F150
Feb 19, 2014 09:19 PM
tidexp
23
Sep 9, 2012 08:37 PM
