Spindle Nut Size?
Old Jun 11, 2007 | 01:10 PM
DRM2004's Avatar
DRM2004
Spindle Nut Size?
I'm going to be replacing my front rotors....
I was wondering what size socket I'm going to need to remove the spindle nuts?
I found a post that said it was a 36mm? But wanted to verify this.
Thanks.
Old Jun 11, 2007 | 01:33 PM
Cuisinart's Avatar
Cuisinart
Well, I'm not sure about the size but it really doesn't matter. All you have to do to change the rotors is take the wheel and caliper off.
Old Jun 11, 2007 | 01:46 PM
black04lariat's Avatar
black04lariat
yea just take the caliper off and then you may have to bang the rotor off but thats it. did in last month. easy. the front and rears are the same way. no need to take it off.
Old Jun 11, 2007 | 04:23 PM
DRM2004's Avatar
DRM2004
Do you guys have a 4x4 or 4x2? The 2wd's have a rotor/hub assembly that I thought was one piece (unable to remove).
Old Jun 11, 2007 | 06:43 PM
Cuisinart's Avatar
Cuisinart
4x4, I wasn't aware the brakes were different.
Old Jun 11, 2007 | 06:54 PM
black04lariat
<TABLE><TBODY><TR><TD vAlign=top width="100%">4x4, I wasn't aware the brakes were different</TD><!-- KEN: 1-13-2007: show 300x250 ad-block to non-Club FTE users in the 1st post of every page --><!-- / Ken, end of hack --></TR></TBODY></TABLE>
x2. i didnt know that either
Old Jun 13, 2007 | 06:49 PM
bamorris22's Avatar
bamorris22
Yes, 2WD vs 4WD makes a very big difference on these trucks. Speaking from experience, on the 2WD models (which is what I have) the rotor, hub, and bearing are all one non-serviceable part. Thus the reason that the rotors for the 2WD's are sooooo expensive, $150-$250 EACH!
And yes, the correct size is 36mm, and it must be a deep socket. Best bet is to use an impact socket. Also note that Ford requires new spindle nuts every time you remove them. They cannot (well, SHOULD not) be re-used (they're even stamped "DO NOT REUSE"). They run $20-$50 depending on where you get them ($55 from the dealerships). And they need to be torqued to 295 lb/ft. You'll need a heavy-duty torque wrench to go that high... Procedure is to tighten spindle nut to 295 lb/ft, rotate counter-clockwise 5 times, then re-check torque.
Oh yeah, you'll also need 2 new cotter pins to hold on the castle nut which goes over the spindle nut.
REGGIE_OBE
1997 - 2003 F150
Jul 7, 2016 07:49 PM
Royson12
Apr 26, 2016 04:59 PM
Seanosu
Mar 4, 2016 04:47 PM
TyBragg
19
Oct 26, 2012 06:26 AM
Franko72
Oct 2, 2012 09:08 PM
