Machining Intake?
Old Jun 11, 2007 | 01:05 PM
wvbogger's Avatar
wvbogger
Machining Intake?
I have a 77 460 that the block was 0 decked. they removed .025" The heads are getting .01 removed. Will the intake need to be machined?
THANKS
Old Jun 12, 2007 | 10:50 AM
airharley's Avatar
airharley
I found a milling guide a few years back using google. It demonstrated how much to take off where in reguards to what work was done to each component. I am searching for it now. I'll post back with it when I find it. I do know that it is better to mill the heads intake flange, for lack of better words, so you can swap out the intake later on if needed without milling that as well.
Old Jun 12, 2007 | 10:53 AM
monsterbaby's Avatar
monsterbaby
on 90 degree engines like the 460 they recommend taking off the same amount from teh intake as you take off the block and heads combined so the intake should be .035 off, or take that amount off the intake side of the heads (my preference because the heads will always need some removed but the intake might get moved to another engine. But personally I would mock up the engine and set the heads down and check the port alignment if you can. otherwise that is the general rule for these engines.
hotrod351
Sep 7, 2018 05:10 PM
jbg machine
Nov 30, 2014 09:26 PM
taylor90
18
Dec 17, 2011 10:29 PM
jbulson
19
Dec 30, 2002 10:48 AM
dinosaurfan
Feb 4, 2001 08:52 PM
