Gauges 101
Old Jun 7, 2007 | 03:20 PM
Headrope's Avatar
Headrope
Gauges 101
I've used the search function to try and find answers to my guage questions but ended up with more questions so decided to start this thread for all the newbies like myself.
I just purchased an '05 F350 Superduty with the 6.0. It has a manual transmission and I plan to tow with it. What guages should I install and why?
Old Jun 7, 2007 | 03:39 PM
blackhat620's Avatar
blackhat620
Other than the Transmission Temp gauge (which is not needed for a manual transmission) what else is different???
You have a 6.0 other than an automatic transmission, everything else is the same, and the multiple previous gauge posts sum it up.
Old Jun 7, 2007 | 04:53 PM
Gigante's Avatar
Gigante
You really only need one :
Pyro - to monitor your exhaust gas temps.
Do 05's have the boost gauge in the dash? If no, you could get one of those to, well, monitor your turbo boost.
Old Jun 7, 2007 | 05:21 PM
Headrope's Avatar
Headrope
The '05 has a boost gauge within the instrument panel.
Why does knowing what my exhaust gas temperatures are matter?
Old Jun 7, 2007 | 05:47 PM
Beerstalker's Avatar
Beerstalker
If your EGTs get too high the turbo can be damaged.
Old Jun 7, 2007 | 07:20 PM
WishIhada7.3's Avatar
WishIhada7.3
he really doesnt even need a EGT guage if he doesnt plan to chip it....on a stock tune towing it shouldnt get hot enough to do any damage the clutch would prob slip first.
Old Jun 7, 2007 | 08:50 PM
mrxlh's Avatar
mrxlh
Good catch 7.3, as the manual trans verision is rated at less towing capacity. I still like the eget gauge, just for peice of mind though.
Old Jun 7, 2007 | 09:43 PM
UGA33's Avatar
UGA33
Same here. Towing uphill on a stock truck can still put you pretty close to dangerous egt's.
Old Jun 7, 2007 | 09:50 PM
mrxlh's Avatar
mrxlh
Yep and you can puke a stock truck pushing it too hard towing. I know that from firsthand experience.
Old Jun 8, 2007 | 02:36 AM
Headrope's Avatar
Headrope
What does "puke a stock truck" mean?
Old Jun 8, 2007 | 03:01 AM
blackhat620
"Puking" is when engine coolant comes out of the overflow bottle. When things get to hot especially under load the coolant "pukes" out the overflow (degass) bottle. This can also be caused by blown headgaskets, engine oil cooler or leaking EGR cooler.
Hope this helps
Old Jun 8, 2007 | 07:03 AM
U.P. Builder's Avatar
U.P. Builder
Hope this helps
So if it pukes, does that necessarily mean you have one of the above problems? I have some coolant residue on the degas bottle that was there when I bought the truck. No issues and hasn't done it to me but I haven't hauled with it yet. I will be towing the 5er today but it's a small one, only 5500 lbs loaded and it will be a short trip.
As for guages, I see someone that sells Autometers with the pillar pod, 3 gauge set complete for $269 on Ebay. Probably the way I'll go. I really want a good tranny gauge and egt temp.
Old Jun 8, 2007 | 08:22 AM
Lonewolftx's Avatar
Lonewolftx
Wink try this . . .
You might check the TSB's (6-21-2) as there was an update to the bottles on '05's as they were labled wrong from factory and had the fill lines marked wrong on the bottles. A sticker was provided by the dealers to correct where to fill the bottles. Here is link
https://www.ford-trucks.com/tsb/full...y=2005&m=F-250
BeastF-250
Dec 25, 2010 02:30 PM
strokin'_tatsch
Aug 25, 2010 08:22 PM
hotshothauler
16
Nov 8, 2005 10:35 AM
Mopey
Nov 19, 2004 04:28 PM
BLACK350/6.0L
Nov 18, 2004 01:23 AM
