Offset Concave "washer" in front of cam gear?
Do you have the thing in your hands? It should consist of two parts, an inner non rotating center and the outer rotating race that the fuel pump arm rests on. There should be a tang that fits inside the cam gear hole. It looks like the one in the picture.
http://store.summitracing.com/partde...3&autoview=sku
Yes,
I have it in my hand, it's one piece though, and only one hole (offset hole) in it.
In fact, on the cam facing side I can see the marks left from the notches in the cam gear.
I guess it's possible someone was in here before, but with the amount of slop that the timing chain had, I don't know what they did..certainly wasn't to replace the chain
My eccentric on my 77 460 doesn't look anything like the one you guys posted from Summit. I attached one that looks something like mine but I don't remember two holes in it. It just has the one offset hole and is a one piece unit. You just bolt it to the cam and torque it down. Where it ends up is where it is.
Originally Posted by 3Mike6
That looks more like mine...i/e the thicker material and also without the 2nd hole.
Reading through some other sites I saw reference to using a "one piece eccentric" as well.
Thanks for confirmation!
Ranger92
12-19-2008 07:18 PM
fastmover
08-28-2007 12:15 AM
jaimalade
05-20-2003 09:00 PM
