Injectors AA or AB?
Old Jun 6, 2007 | 04:35 PM
tjbeggs's Avatar
tjbeggs
I don't know alot about the BTS setup but it uses another housing in place of the HPOP reservior and there is the gear that messes with the stock gear to drive second pump. Not sure what they do for a new reservior.
Old Jun 6, 2007 | 05:57 PM
MADVAN's Avatar
MADVAN
BTS HPOP
About the same install for OBS. Just add fuel system.
http://community.webshots.com/album/551171470
Bill
Old Jun 6, 2007 | 09:52 PM
bigbadwolfe's Avatar
bigbadwolfe
O M G that link is no joke
Old Jun 6, 2007 | 10:32 PM
mustangz911's Avatar
mustangz911
That is some trick s$$$.I got to have one of those.Where do you relocate the fuel filter housing.Awesome
Old Jun 7, 2007 | 07:16 AM
tjbeggs's Avatar
tjbeggs
Pretty much if you need big oil you need an electric fuel system with larger filters anyway. So you ditch the stock fuel filter housing and reloated some filters under the truck.
Old Jun 7, 2007 | 02:51 PM
Neal 97 250's Avatar
Neal 97 250
OK so I understand. That truck has the mods. With that being said do you think 17* will be fine with 160 or 180 Stage II's as long as I cantolerate the CEL until I can do the big pumps and fuel? Or should I just stay humble and do the I's?
Old Jun 7, 2007 | 03:01 PM
tjbeggs's Avatar
tjbeggs
Yeah you can run the 2's on stock oil all day long as long as you can put up with the CEL. Your not hurting anything either. you just don't get all the power you can with out big oil. Big oil is even noticeable with stock injectors from what I hear.
Old Jun 7, 2007 | 03:05 PM
Neal 97 250
Cool I believe that I need to do the 17* mod but will the 15* support them until I do(just in case I do the II's first)? Also correct me if I am wrong... I will see more performance from II's than I's even if all I have is the 15* or 17*. Thanx and forgive the ignorance, Y'all are great.
Old Jun 7, 2007 | 03:13 PM
tjbeggs's Avatar
tjbeggs
yes the 15* will run 2's until you can get the 17* or even if you don't get the 17*. yes you should see more performance from 2's even with out big oil. They have larger nozzles so they can push the fuel out faster. you will have alot of smoke though so be ready for that. 2's especially without the oil pressure up to the task will smoke quite a bit. with the larger nozzles the fuel doesn't atomize as well.
DadWas_a_ChevyGuy
Dec 15, 2014 03:28 PM
dcelrod
Nov 6, 2014 05:32 AM
clint stafford
Aug 27, 2014 09:08 PM
Splatts
Jan 24, 2012 04:09 PM
mustang_309
Apr 26, 2005 12:36 AM
