Fuel injectors
Old Aug 26, 2014 | 07:48 PM
clint stafford's Avatar
clint stafford
Fuel injectors
My name is clint I have a 97 7.3 my 7.3 has 2 different types of injectors 6 ab and 2 aa I was just wondering if I need to put 2 more ab in it I have a aa going out
Old Aug 27, 2014 | 07:16 AM
fordpride's Avatar
fordpride
Welcome to FTE !
Your injectors should all be the same codes
It's also possible that someone swapped the solenoids as they're all the same.
How does it run ?
Old Aug 27, 2014 | 08:32 AM
strokin'_tatsch's Avatar
strokin'_tatsch
If those 6 that say AB on them actually have AB internals, then those injectors shouldn't be in your truck unless it's a Cali truck.. A 49 state truck should have AAs in all 8 holes if they are factory injectors.
Old Aug 27, 2014 | 10:27 AM
clint stafford
I bought the truck about 3 months ago 2 of the injectors where bad rebuilt the 1 worked an 1 didn't num 7-8 are the aa but it runs good but have the bad one
Old Aug 27, 2014 | 07:57 PM
fordpride's Avatar
fordpride
Have you checked the wiring tontine injectors ?
They're a known problem
Old Aug 27, 2014 | 09:08 PM
clint stafford
Yes new valve cover gasket with harness it was a bad injector put rebuilt one on it worked fine
mgraveman
Apr 14, 2016 09:28 AM
kbarbee95
Nov 4, 2014 09:22 PM
andres0517
17
Feb 12, 2013 03:09 PM
airassaultinfantry1
13
Nov 5, 2009 06:12 AM
tooblue
May 13, 2008 10:26 PM
