'56 F-100 instrument panel
Well, it's about time for me to get my instrument panel installed, and I was thinking about using aftermarket gauges.
Any recommendations for an instrument gauge panel for a '56 F-100 that will hold round aftermarket gauges? List of suppliers?
What I'd like is a bolt-in panel that will look right and hold a round speedo and four smaller round gauges, that will sort-of look like a '56 Ford car only smaller.
--van
--van
on
These ones are nice, IMHO, I have a set in my 53 F100.
http://www.dakotadigital.com/index.c...rod/prd147.htm
I saw a picture (should have copied it) where someone removed and replaced the mid fifty gauges from behind the stock instrument panel and installed "small" round modern gauges.
By example, you could see the "E" and the "F" of the fuel gauge, as well as the arched line and needle in between, but you could not see the center/pivot pin that the needle attached to.
It was a pretty nifty blend of modern and nostalgic, which I plan to explore when I get to that phase of my project... which will include a re-wire and use of matching senders.
FWIW...
Brian
FWIW...
Brian
Wayne, how old is that picture? LOL... That's a great looking dash you got as is your whole truck, but that battery has to go.... I kept the original dash in mine because I like the look of the speedometer and gauges. Gives it that classic look. This is what my interior looked like when I bought the truck.The speedometer and gauges actually worked! LOL. I painted the dash insert to match the dashboard so it blends in nicely without standing out. I think the dash is the only thing I've left the same???- AWWWW! Those are Porsche high back seat. Nice!!!!! Never did figure out what those switches went to?????
Here's a newer shot.
kdwyer
1983 - 2012 Ranger & B-Series
13
11-20-2021 04:18 PM
I_Am_Ozymandias
02-27-2015 06:07 PM
