Gauges
Old Oct 9, 2013 | 11:39 PM
Niblett85's Avatar
Niblett85
Gauges
The gauges in my 76 f250 where sagging and not looking proper through my dash panel so I took it off and the instrument panel backing is rotten there is no saving it along with the circuit board that the gauges are connected on. I need to replace these any suggestions I want to stay fairly cheap and don't like the aftermarket round gauge look too much
Old Oct 9, 2013 | 11:48 PM
mikeo0o0o0's Avatar
mikeo0o0o0
The backing and pc board are both available aftermarket. Dennis Carpenter, National Parts Depot and LMC all carry them.
This is a fairly common problem with the instrument cluster. The backing was made of a composition material that after a few years would basically turn to dust. The new and reproduction pieces are made of an improved plastic.
If you want to go the salvage yard route, the same basic cluster was used in the Econoline vans up through the eighties.
Old Oct 10, 2013 | 02:25 AM
Jdeshler's Avatar
Jdeshler
I pulled one once and it turned to sand before I could get it past the steering wheel.. then i have been to the junk yard and found them like new .. but like mike said the new replacements are better plastic so if you decide to rebuild it it'll stay with you another good 30+ years..
Old Oct 10, 2013 | 02:36 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
CARPENTER NOS OBSOLETE PARTS in Concord NC (800-476-9653) has both of the following cluster backs. They are NOS (New Old Stock) genuine Ford originals, not repro's.
You can also find both in junkyards, see the Econoline applications. Econolines are also your friend for used printed circuits.
E1PZ-10848-A .. Hard Plastic Instrument Cluster Back-Use with Oil/Amp GAUGES: 1981/91 Econoline.
E1PZ-10848-B .. Hard Plastic Instrument Cluster Back-Use with Oil/Amp WARNING LAMPS: 1981/86 Econoline.
Both of these Econoline Hard Plastic Cluster Backs were the service part replacements for the POS cluster backs that TURN TO DUST on 1975/79 F100/350 - 1975/80 Econoline - 1978/79 Bronco.
D6TZ-10K843-B .. Printed Circuit Board-Use with Oil/Amp GAUGES / Marked: D6TF-10C956-BA / 1976/79 F100/350 - 1976/91 Econoline - 1978/79 Bronco.
D6TZ-10K843-C .. Printed Circuit Board-Use with Oil/Amp WARNING LAMPS / Marked: D6TF-10C956-CA / 1976/78 F100/350 & Econoline - 1978 Bronco.
D9TZ-10K843-A .. Printed Circuit Board-Use with Oil/Amp WARNING LAMPS / Marked: D9TF-10C956-AA / 1979 F100/350 & Bronco / 1979/86 Econoline.
dmccorkle911
26
Mar 30, 2022 09:08 PM
hermancm
Jun 20, 2017 07:18 AM
Nitro901
15
Nov 6, 2014 02:18 PM
77_f250_custom
Oct 13, 2014 05:54 PM
Snafu_Bohica
Nov 27, 2012 10:07 PM
