Bolts attaching snailshells to main
Old May 29, 2007 | 10:08 PM
powerstroke6ltr's Avatar
powerstroke6ltr
Anyone know what the 1/2" bolts holding the snailshell halves to the oil supply block should be torqued to?? The wastegate bracket is held by 1 bolt and the rest were not finger loose but easily turned by my wrench... Thinking ATS purposely didn't tighten the bolts down...? Would that lead to boost leaks and oil leaks? Also my valley is wet with diesel but can't seem to see from where....thanks on any help!
Old May 29, 2007 | 10:27 PM
PLC7.3's Avatar
PLC7.3
If you are looking for 2003 truck info you must move up a few forums..... thanks, if not please give us year and truck info.......
Old May 29, 2007 | 10:36 PM
catfish101's Avatar
catfish101
Go with standard bolt torque.
Old May 29, 2007 | 10:41 PM
powerstroke6ltr
For some reason my signature won't work... its a 92 f-250 7.3 ATS aurora 3000 turbo ZF-5...my mistake
Old May 30, 2007 | 05:07 AM
PLC7.3's Avatar
PLC7.3
Try going up to quick links above and do signature again.......
Standard torque for 1/2" X 13 UNC is 60 ftlbs
Old May 30, 2007 | 06:23 PM
crazymike's Avatar
crazymike
you have to have a certain amoun of posts before the signature works i belive its something like 5. dont quote me on that one tho im not sure. check the top of your engine for fuel. it may be leaking form the return lines like os many others.
Old May 31, 2007 | 12:00 AM
powerstroke6ltr
Checked everything over. The truck won't even start now. Not getting any fuel... The solenoid doesn't click anymore. I was removed/unplugged the main harness on the drivers inner fender to do some work. Now it won't start. Any ideas now?? Need the truck tomorrow morning....
aclaybor
Apr 5, 2015 11:43 PM
ldsparamedic
Jan 19, 2014 01:10 PM
my996duc1
6.7L Power Stroke Diesel
Dec 3, 2012 10:59 AM
Jayme Duty
Feb 2, 2011 04:29 PM
72mach_1
13
Sep 14, 2005 05:29 AM
