torque on valve covers
Old Feb 2, 2011 | 02:44 PM
Jayme Duty's Avatar
Jayme Duty
i've got a bad oil leak that i traced coming down the manifold and up to the rear valve cover bolts. I got 1.5 rotations out of the first bolt with out even trying. I want the proper torque so i don't over doit and snap a bolt off or strip one out.
Old Feb 2, 2011 | 03:18 PM
tjc transport's Avatar
tjc transport
i ain't rite
they are only 1/4-20 bolts, so torque is only going to be like 5 to 8 foot pounds.
i snug them with a 1/4 inch drive snubby ratchet if i cant get a torque wrench on them.
Old Feb 2, 2011 | 04:29 PM
socalwrench's Avatar
socalwrench
I used to work with a tech. that would go until his little 1/4 drive air ratchet started to feel a load. You could almost hear it. It was probably 10 foot pounds. For the valve covers you have to make sure it goes on flat and even. I always did the valve covers in three steps; in a circular pattern- hand tight, light force with ratchet, medium force with ratchet. If it's an old engine with stamped steel valve covers, try using those load spreaders that are 3-4" long. They help keep it all flat with tightening it.
dmanshane
15
Feb 26, 2012 09:01 AM
Aggie05
1983 - 2012 Ranger & B-Series
Oct 9, 2008 09:09 PM
cdiddy
Aug 18, 2007 06:48 PM
norm805
Jan 26, 2007 09:50 PM
Andy_Bracy
Jul 10, 2005 12:31 PM
