Sponsored by: Real Truck
Need Code info....
Old May 29, 2007 | 07:35 PM
donjamer's Avatar
donjamer
Need Code info....
Well after having no start problems this weekend it is fixed..
Cause was the alarm relay..
If you want to read the full story here is the link.
https://www.ford-trucks.com/forums/6...ont-start.html
Now after changing the relay and driving I noticed the check engine light on..
Scanned for codes with the scanguage II and found there were 2 error codes.
Code P0404 and U0155
I reset the codes and they have not come back..
I did disconnect the batteries in troubleshooting the no start problem..
Hopefully it is just because of that..
Any help with the codes is greatly appreciated.
Is there a website that has the codes listed?
Old May 29, 2007 | 07:54 PM
redford's Avatar
redford
FTE Leadership Emeritus
This very site has the codes!
https://www.ford-trucks.com/article/..._Overview.html
P0404 Exhaust Gas Recirculation Circuit Range/Performance
U0155 Lost Communication With Instrument Panel Cluster (IPC) Control Module
Both would seem normal given what you just went through.
Old May 29, 2007 | 08:37 PM
donjamer's Avatar
donjamer
Thanks Redford...
I was thinking it should be here, but I couldn't find it.. Guess I didn't dig deep enough..
I know the U0155 error was because I blew the Instrument panel Fuse.
Not sure why the EGR code came up though..
Thank again
Stewart_H
Oct 24, 2017 11:57 AM
RSCHAP1
Mar 31, 2016 11:28 AM
Tim Hodgson
Feb 12, 2015 09:56 AM
Archuriel
Oct 8, 2013 08:25 AM
gladiator4113
Jun 9, 2011 04:38 AM
