EGT's at idle- how low do you go?
Just curious. Haven't seen many of these, but the right angle is kind of nice... The funny part is that when I put in my gauges, I did the pyro first because I figured it was going to be the biggest pain. I think I was done with it in 15 mins. The d@mn T-fitting for the boost gauge was the pain!! The ITP Overboost Annihilator hose is a bit thicker than stock, so the ID is smaller. I had a hell of a time getting that T in there!! I think I fought with it for at least 30 mins.
I used a piece of the original hose for the section between the T & manifold.
Joe
Joe
my pyro temps are pre turbo... after just running down the highway to work... a few minutes of idle will bring it below 300.. i shut it down at that point... however, if i have been towing... i let it idle a lot longer and i let it cool down below 250, i'll even let it go down to 200 if it will get down there...
This is my version, which uses a welded bung in the up-pipe that was done by a diesel shop in Las Vegas, NV in Nov, 2001, but he pic is recent. Before this was done, I had the probe in the Banks downpipe, and I was amazed how much faster the EGT responded to the throttle (both up and down) after I had the probe moved to the pre side. Does anyone see any exhaust leaks or whatever, the pipes are looking pretty rusty to me, but I guess that's par for the course for an 8.5 year old truck!
Originally Posted by powerstrokin007
So the up-pipe is the best spot or accurate temps.
Originally Posted by Fat Diesel
Maybe, but when you have to replace the up-pipes, do you really want to have to move the probe? I wish I would have put it in the manifold.
