Aerostar Ford Aerostar
89 lower ball joint replacement
Old May 28, 2007 | 04:48 PM
Details's Avatar
Details
I was going to replace the lower left ball joint on my 89 Aerostar but my Chiltons manual and the dealer both say it is not replaceable, you have to do the entire control arm - a $250 part! Is the 89 special or can I use an aftermarket product to replace it? Thanks for you input.
Old May 28, 2007 | 06:09 PM
96_4wdr's Avatar
96_4wdr
http://www.rockauto.com/catalog/raframecatalog.php
site sponsor, give them a call
they stock several top quality name brand LBJs for '89
fast low cost drop shipping
Old May 28, 2007 | 07:47 PM
Details's Avatar
Details
Thanks for the lead.
Old May 28, 2007 | 08:18 PM
copper_90680's Avatar
copper_90680
Hi Details
Welcome to our FTE forum.
Do a search. It has been done before without having to replace the entire control arm.
Old May 28, 2007 | 09:45 PM
krankshaft's Avatar
krankshaft
Thats just bunch of dealer bull. I'm sure Ford made a killing though when it came to replacement .
The lower BJs have to be pressed out you can rent the tool its just a big C-clamp with a round adapter to be placed under the joint.
You place a round catch that comes with the tool where the joint will come out then install the clamp.
Tighten the clamp with a socket wrench until the joint comes out of the bottom. Reverse the process to reinstall.
Old May 29, 2007 | 07:09 PM
tom_foreman's Avatar
tom_foreman
You can do it. It's not too hard. I rented the press from Autozone. I had a hard time trying to figure out how to put the press into use. I found this website with pictures on getting the ball joint in and out. Note that in the pictures the press upside down compared to what you will need with the Aerostar.
The upper ball joints are another issue. Much harder.
Old May 30, 2007 | 04:53 AM
Pablo-UA's Avatar
Pablo-UA
I used to replace upper ones. A bit harder. Just cut away 6 riviets and that is all.
To install use bolts.
Old May 30, 2007 | 06:38 AM
krankshaft's Avatar
krankshaft
To remove uppers you will need to remove the rivets either drill them out or chisel them out. The new ones bolt on.
To drill them out use a center punch to place a dimple in the center of the rivet so your drill doesn't wander. Once you have gotten through remove the top half or the rivet and pound out the rest with the center punch.
To chisel them out I would use an air chisel however since that method seems like it could damage the upper control arm I would use the drill method.
Old May 30, 2007 | 07:18 AM
Pablo-UA's Avatar
Pablo-UA
I've just replased lower BJs.
I used no press. A big hummer only. Old were easily nocked away. 1 hour job.
Old Jun 3, 2007 | 10:37 AM
pbrunner's Avatar
pbrunner
Just a tip for 4WD owners who may search this topic. I just replaced mine and the C-clamp tool I used will just barely fit, but I had to pull back the CV boot. Put a piece of thin sheet metal between the threads on the tool and your CV Joint to avoid damage.
Old Jul 30, 2007 | 04:38 PM
Details's Avatar
Details
Thanks for all your input, you were right not that big of deal.
jimwesselman
1997 - 2003 F150
Apr 16, 2008 02:56 PM
03redranger
1983 - 2012 Ranger & B-Series
Feb 22, 2007 04:28 AM
gwillhide
Jul 24, 2006 08:36 AM
98expeditionXLT
Oct 19, 2005 03:20 PM
89 bronco II
Oct 6, 2004 08:30 PM
