Regulator problem?
Old May 27, 2007 | 10:31 PM
Locoster's Avatar
Locoster
Regulator problem?
The past few days my batteries are drained over night. I assume this is a regulator problem in the alternatror. Yes or No, am I on track? It is in a 2000, E350 extended 15 passenger van, and appears to have a single alternator and the parts pages show both a 130amp and a 215 amp alternator. How do I tell which I have? It is not really big--maybe 4 1/2 to 5 inches long, and I am guessing about 5 inches in diameter. Some fast help would be appreciated, as I have a 3 day road trip starting tomorrow morning, and I would like to pick up an alternator on the way.
Old May 27, 2007 | 10:35 PM
MAKO314's Avatar
MAKO314
on a van more than likely the small one unless you have lots of factory electronics
Old May 27, 2007 | 10:51 PM
ernesteugene's Avatar
ernesteugene
Check out this link 2000 Ford E350 w/Single Alternator Standard (Ford) (130 Amps)
http://www2.partstrain.com/products/Engine/Engine_Electrical/Alternator/2000~FORD~E-350_ECONOLINE_CLUB_WAGON~8~7-dot-3~E350-SD_CHATEAU-004.html
Old May 27, 2007 | 10:52 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
I think the big alternator is only part of the ambulance prep package. Everyone else gets the 130.
Old May 27, 2007 | 11:30 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
TO me it sounds like the AC rectifier in the diode bridge in the alternator has gone bad. It's passing my memory now, but i do know that if the AC rectifier has gone bad, it will slowly drain DC current from the batteries and leave them dead overnight. The voltage regulator just regulates the output voltage analogy-istic of a throttle plate on a gasoline engine.
Old May 27, 2007 | 11:45 PM
Locoster's Avatar
Locoster
Where Do I Find Replys To This Post?
Old May 27, 2007 | 11:50 PM
Locoster's Avatar
Locoster
Would it be better to take the alternator in for service, rather than replacing it?
PS:
(Replying to my own post brought up the other messages for me)
Old May 28, 2007 | 12:04 AM
cookie88's Avatar
cookie88
FTE Emeritus
PS:
Not all that many starter/alternator shops around any more. It would be faster to just replace it.
Old Jun 13, 2007 | 01:46 PM
crosbo's Avatar
crosbo
I apologize for hijacking your post...but I have a similiar problem...battery light flickering.
So, I checked both batteries independently and both are registering 15v+.
Next I pulled the connection on the alternator, checked both lines and found 13v+ on one and a similiar reading on the other when the ignition was on in "run".
Next I checked for voltage at the charge post of the alternator, yep, 15v+ so I can rule out a fusible link problem.
Next, pulled the charge line from the alternator, started the Stroke and turned the AC blower on high and the headlights on high...checked voltage coming out of alternator and it only registered .3v
So, bad alternator...or just bad voltage regulator? Can the voltage regulator be changed in these?
Old Jun 13, 2007 | 01:52 PM
vettdvr's Avatar
vettdvr
Been there done that so many times I don't fool around. I just replace the alternator. Keep it simple. Jim
LipschitzWrath
22
Aug 14, 2017 05:22 AM
LWolffe
Aug 25, 2014 05:12 PM
79FordBlake
Jan 24, 2010 11:55 AM
Andysutt
Oct 14, 2003 02:43 PM
Willie
Electrical Systems/Wiring
Nov 21, 2002 03:53 PM
