1978 - 1996 Big Bronco
Power Windows
Old Jun 7, 1999 | 02:51 PM
Mulletwagon's Avatar
Mulletwagon
Power Windows
88 full size Bronco. What is the drill to remove the power window motor and rebuild the pinion drive ???
Old Jun 9, 1999 | 12:22 PM
dirtman's Avatar
dirtman
Power Windows
I recently replaced the gears in my drivers door of my 88 Bronco. First take off the door panel, then raise the window to the up position and use some stiff wire to keep it up. Take the screws out of the motor and slide the motor and gear assy off the window bracket. Disconnect the wire harness then work the motor and gear assy out of the large opening in the door. When you get it out, you will see 4 screws on the side of the motor assy; take these screws out and you will have access to the plastic gears for replacement. Its pretty easy to do. Hope I have helped out.
Old Jun 9, 1999 | 12:32 PM
dirtman's Avatar
dirtman
Power Windows
I made a mistake. Before you take the motor out you must drill rivets out of the motor assy. (it is riveted to the door). The repair kit I got had new screws, nuts and washers in it for replacement.
Old Jun 25, 1999 | 11:11 AM
Bruce's Avatar
Bruce
Power Windows
Old Jun 11, 2006 | 12:34 PM
tom2131968's Avatar
tom2131968
On the '88 there are three bolts that hold the motor, only one if which you can remove initially. The other two are accessed by drilling holes over the bolt heads so you can get a nutdriver or socket in there to remove. Luckily, Ford made it easy to do this as they put punch marks right over them. Drill right over these marks and you will then be able to remove the other two bolts and hence, remove the motor. Be sure that you secure the window in the "up" position BEFORE you remove the motor. I just use 3-4 long pieces of clear packing tape over the top of the door to do it.
Old Jun 11, 2006 | 02:12 PM
masseysbronco's Avatar
masseysbronco
Exclamation
Those rivets on the inside of the door are threaded and there is 3 of them with a nut on each to hold the motor. I just reached in there and took them off and put them back on when I was done, so I woudn't have to drill out the rivets.
Old Jun 12, 2006 | 11:28 AM
Streetgang's Avatar
Streetgang
This is the correct Ford prescribed method of removing the window motors from the front doors.
Its also the quickest, and if you ever have the problem again.....the holes will be there already making it even quicker to complete.
blazinjames
Mar 3, 2017 10:46 PM
wagoner
2015 - 2020 F150
Oct 28, 2016 11:53 AM
Ford_Six
Sep 5, 2016 07:56 PM
rlay302
1983 - 2012 Ranger & B-Series
May 6, 2016 11:51 PM
wickware
Sep 15, 2004 02:33 AM
