1978 - 1996 Big Bronco
Cold Start Problem
Old Jun 11, 1999 | 11:55 PM
RadarRunner's Avatar
RadarRunner
8th Gear
Cold Start Problem
I have a 1988 Bronco with 302 fuel injected with 103,000 miles. It acts as if it is not getting fuel or enough spark to fire when first turn key. When I try the second, it seems to go ahead & start. It has only recently started this.
Thanks
Old Jun 12, 1999 | 02:23 AM
79bronco's Avatar
79bronco
Cold Start Problem
>It acts as if it is
>started this. Thanks
try a tune up. clean plugs and check timing.
Old Jun 12, 1999 | 02:38 PM
Pastmaster's Avatar
Pastmaster
Cold Start Problem
when you do a tune-up replace the fuel filter
Old Jun 25, 1999 | 11:11 AM
Bruce's Avatar
Bruce
Cold Start Problem
I had a '77 Ranchero that had a similar problem. I found that when cold I could crank and crank the engine and it wouldn't start. The funny thing is that after I let go of the key it would start. It was the wierdest thing and turned out to be the selenoid. When cold and the key was in the start position, the ignition wasn't getting electricity; but it would when the key was released and went to the run position. Fortunately, the engine was still moving and would get spark and start.
Wierd!!!
Bruce
Old Jul 7, 1999 | 03:14 PM
Mulletwagon's Avatar
Mulletwagon
Cold Start Problem
Old Oct 19, 2009 | 09:14 PM
Encho's Avatar
Encho
The Southernmost Mod
Is this the first post ever on the Big Bronco section? or is there any older (and deleted now) one?
Anyway, i'll give it life once more... hehehe... just for you guys to check it out.
Old Oct 19, 2009 | 11:48 PM
g_k50's Avatar
g_k50
Someone has too much time on their hands.
Devil's playground, but I'll play along.
Hahahahahaha
gibbsdakota
Apr 3, 2012 08:05 PM
AFoster1025
Oct 25, 2010 05:48 PM
mino54
1997 - 2003 F150
Dec 22, 2008 12:08 AM
Smokeythebear
1997 - 2003 F150
Mar 10, 2005 05:46 PM
dieselpup
Jan 5, 2005 07:57 PM
