running issues
Old Mar 28, 2012 | 01:42 PM
gibbsdakota's Avatar
gibbsdakota
running issues
my 1994 turbo diesel is hard to start but when it starts it runs for a minute then boggs down and kills itself. what would be causeing this. it was low on fuel and i put fuel in it and this started happening.
Old Mar 28, 2012 | 09:42 PM
86f250XLT-4x4's Avatar
86f250XLT-4x4
air in the fuel system first double check your fuel filter make sure its full then start it up and while its running loosen an injector line one at a time until it smooths out... (with line loose it will idle like its missing (cylinder not getting fuel)
Old Mar 29, 2012 | 07:56 PM
gibbsdakota
gettin it to start is hard let alone getting it to stay running the fuel filter always emptys to about half should i just crank it while i loosein one and then tigtin it up
Old Mar 29, 2012 | 09:13 PM
Aune163rd's Avatar
Aune163rd
sounds like a lift pump problem....if your fuel filter is not filling up when cranking...then its possible that your lift pump is going or its gone....
Old Apr 3, 2012 | 07:47 PM
gibbsdakota
lift pump was bad after 400 dollors of tryin to figure it out lol. we saw it was leakin from the lift pump. runs great now
Old Apr 3, 2012 | 08:05 PM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
i would change the oil now. some fuel could have made it into the crankcase.
WILLYSFREAK
15
Dec 23, 2010 05:14 AM
Farmall05
Mar 17, 2008 07:34 PM
bigdawg460
Jul 14, 2006 04:11 PM
69_4_fun
Jan 18, 2006 08:24 PM
BlueHeavyD
16
Jan 13, 2004 11:09 PM
