ICP pressure norms?
Old May 25, 2007 | 09:34 PM
MAKO314's Avatar
MAKO314
ICP pressure norms?
what is the normal injection control pressure at idle, I checked this on my cousins truck it was around 495-508lbs also I thought the 10K mod boosted the ICP in his trucks case the ICP dropped about 60lbs with the 10K. I checked all of this with AE. any of you guys have any input?
Old May 26, 2007 | 07:08 AM
Uzumati's Avatar
Uzumati
With the 10K the ICP sensor will report lower pressure than what it actually is, that way the PCM can command more duty cycle from the IPR and get more actual pressure. If you were to hook a gauge to the oil rail it will read a bit higher than what the sensor is reporting although at idle it wont be much difference.
patino1
Mar 1, 2025 07:41 PM
Bill Pittman
Jan 13, 2015 07:03 AM
John Irwin
Nov 23, 2014 01:34 PM
renec
Aug 27, 2013 08:13 PM
gamaliel
Jan 7, 2013 08:33 AM
