v-10 Turbo
The last time I checked a turbo diesel has turbo lag.
Turbo chargers can boost in the mid to later 2,000 range, and keep on boosting as different waste gates cut in and out, therefore they work better than superchargers at higher elevations. This is why fighter aircraft built in the 30's used turbochargers (P-38 Lightning, for just one example) Turbo chargers are incredibly simple and are far cheaper to build than twin screw (aka positive displacement) superchargers. I can see no downside to turbos other than the lag factor, and towing doesn't lose a race on turbo lag.
There are kits for the Mustang 4.6, I wonder how much of that can be used for the 6.8 (or even the 5.4)?
As far as the Paxton Kits go, Paxton and Vortech both make full kits for the V10 (excluding Model Year 2002 for Vortech). Vortech does all the R&D for Paxton at their Oxnard facility. They are sister companies. Paxton's kit is a little cheaper than Vortech's. Superchargers on-line quoted me a price:
"You requested a price quotation for: Paxton NOVI 2000 Supercharger Kit for 1998-2002 Ford Truck & SUV with 6.8L V-10 (Satin) [more info]
Part Number: PAX1001911
SuperchargersOnline.com*: $3,699.00
List Price: $4307.95
You Save: $608.95 "
AND
You requested a price quotation for: Vortech Supercharger Kit for 1999-2003 Ford F-Series/Excursion Super Duty with 6.8L (V-2- SQ S-Trim, satin) [more info]
Part Number: V4FT218-020SQ
SuperchargersOnline.com*: $3,899.00
List Price: $4576.95
You Save: $677.95
Do you guys think that this would work on a V-10? It says in the description that it would fit on ALMOST any vehicle. It just doesnt come with the intake or exhaust tubing, fuel management or tuning.
I was on the phone with Paxton and Vortech, (sister companies) You don't get max boost until you hit max engine rpms. You get partial power at 3 grand. Not good enough for me. STS is the best way to go. You get variable pressures as conditions demand, and get a free ride......no parasitic loss of power.
While you are very correct about parasitic loss of power, todays positive displacement superchargers have very little parasitic loss due to the use of bypass valves to relieve the pressure on the intake and drive side of the supercharger. Under boost, it does indeed take power to run the charger. Like money, it takes some to make some.
The turbo is not a free ride. I don't really know why people get this idea. It does extract potential engery from the exhaust gases. But think of what would happen if a normally aspirated vehicle had a restriction in the exhaust that created 60 psi of backpressure? Ever drive a car with a clogged cat? A turbo charger must be considered as two different systems. The drive side, or turbine, and the output side or the compressor. The turbine extracts energy from the exhaust, and transfers it to the turbo shaft. The amount, speed and range of the energy extracted is dependant on the sizing of the turbine wheel, housing, and piping to and from the turbo. The energy needed by the compressor wheel to do the work demanded, flowing the required amount of air, is dependant on the size of the wheel, and the compressor housing. If the compressor demands too much energy, there will be lag. If the turbine makes too much energy, the compressor will overspeed and get out of it's efficiency range.
Sized and engineered properly, a turbo can operate with low lag, and low end boost numbers. But just like the tradeoff between a centrifugal and PD super, it won't make the power it could up top. That is why you see engines like the 6.4 with variable geometry and/or dual turbochargers, to try and operate the setup at peak efficiency throughout the operational rpm range.
Taking into account the inherent exhaust restriction that a turbo creates, then yes it is a free ride.
However, a bypassed supercharger takes less than .5 horsepower when it is not under boost and has a bypass valve, so it is probably a wash.
