pyro mount...whats the diff.....
Old May 24, 2007 | 09:11 AM
buckshot047's Avatar
buckshot047
bewteen the size "r" and the 5/16 drill bit.....autometer says to us a 5/16 and all I see on here is to use a size "r"....also how hard is it to match the 2003 ford tan color....i used duplicolor in desert sand and its close but for sure not exact....any help appreciated.....Thanks
Old May 24, 2007 | 09:20 AM
Bear Hunter's Avatar
Bear Hunter
http://www.truckblog.com/story-1312-...n_project_jakd
Go to page 5 and that will explain your question on the drill bit sizes
The begining of the article addresses Pod Prep and paint.
Old May 24, 2007 | 02:28 PM
blackhat620's Avatar
blackhat620
r = 0.339"
5/16 = 0.3125"
21/64 = 0.328"
The "r" bit is the proper bit to use, a 21/64 can be substituted, but you must becareful not to break off the tap in the hole. A 5/16 in my opinion is to small to tap with as it is to easy to damage the threads or break the tap. Get the proper "r" bit as recommended by the Tap size and it makes things much easier.
Old May 24, 2007 | 03:38 PM
captaincook's Avatar
captaincook
Bear Hunter .....that is an awesome looking truck!
Old May 24, 2007 | 03:53 PM
Bear Hunter
captain...thanks man
...and Blackhat is correct, it takes a little more effort to tap after using 21/64 drill bit, but it is doable because it is relatively close to the Type R" in size.
Old May 25, 2007 | 09:56 AM
wyoguy's Avatar
wyoguy
Kinda on the same subject! Does anyone make an electrical boost gauge, one that you just plug in to wiring harness somewhere? Much like the Edge display does.
All I can seem to find is the drill and tap type with the vacuum hose route.
Old May 25, 2007 | 10:30 AM
blackhat620
Yes, there is the Bully Dog Outlook Monitor and the Quadzilla Commander, both are just electronic gauge monitors that tap into the map sensor. The drill and tap method is little more accurate, but the electronic tap at the map sensor will be close enough.
Hope this helps
Old May 25, 2007 | 11:11 AM
wyoguy's Avatar
wyoguy
Thanks blackhat, but I was thinking more on the lines of a stand alone 2" gauges. Already have pyro, was wanting to add a boost gauge. Just thought maybe someone made an electrical one.
Old May 25, 2007 | 11:24 AM
blackhat620
None that i am aware of.
Old May 25, 2007 | 07:17 PM
mrxlh's Avatar
mrxlh
Well I will tell your this, it would probably take you longer to wire the connection in than it would to remove the intake elbow and drill and tap it and reinstall it. Like Blackhat mentioned it is more accurate in 2 ways, the readout (mine is about 2-4 psi difference and the sensativity, the one in the intake elbow reacts quicker than the one in the dash.
Old May 27, 2007 | 12:01 AM
captaincook
Where can you get these boost gages and how much are they roughly? Thanks in advance!
Old May 27, 2007 | 12:21 AM
blackhat620
Most of the major gauge makers make boost gauges, ie Isspro, Auto Meter etc. You can get them from any dealer. LIPD has them www.lidiesel.com
Hope this helps
puman
Garage & Workshop
Jan 10, 2015 12:38 PM
queen of spades
15
Oct 6, 2013 11:41 PM
noshow
Jun 10, 2011 10:13 AM
boss66
Mar 23, 2011 02:54 PM
jr1960
Oct 1, 2008 11:12 AM
