Boost Guage Flutter
Old May 27, 2007 | 12:14 AM
levi'sford's Avatar
levi'sford
Boost Guage Flutter
Just had some guages put in (along with cat test pipe, SCT XCal II), and the boost flutters pretty good from 15 to 25 PSI. The guages are Autometer Phantom Series II. Levi
Old May 27, 2007 | 12:28 AM
blackhat620's Avatar
blackhat620
Check the install, more than likely it is installed in the MAP sensor line with a T. Remove it from here and drill and tap the cold air return elbow on the top front of the engine and install the hose there.
Old May 27, 2007 | 12:31 AM
levi'sford's Avatar
levi'sford
Thank you, that is how it is installed, I will do that on Monday. Thanks, Levi
Old May 27, 2007 | 12:32 AM
c.f.moore's Avatar
c.f.moore
Check and see if the pressure tube was installed by teeing into the black hose at the right rear of the engine, just by the heater housing. Can't recall the name of the sensor that is at the end of the hose. Lots of places tee into this line as it's easy.
Unfortunately, some gauges flutter with this connection. Mine did, I tapped into the intake elboe and solved the problem.
Good luck.
Old May 27, 2007 | 12:33 AM
levi'sford's Avatar
levi'sford
What size tap is needed, Levi
Old May 27, 2007 | 12:39 AM
blackhat620
Tap size will depend on the size of adapter you are installing in the elbow. If it is 1/8" NPT then you will need a tap of this size.
levi'sford
Aug 2, 2010 08:50 AM
worm5932
Apr 29, 2010 07:00 PM
SteveBricks
S. California Chapter
Apr 25, 2009 10:41 PM
levi'sford
Jun 26, 2006 06:57 PM
