Hrm...
Old May 23, 2007 | 10:35 PM
Titantis's Avatar
Titantis
Question Hrm...
Well, here goes guys, I just installed headers on my 1977 F100 w/351W, and I started it and annoyed the neighbors for a while, drove it down the road (which was a retarded move because I forgot I had left several tools and an extra carburetor under the hood unsecured, but luckily nothing fell out) and when I parked it, it had been running UBER hot, and there was a boiling sound coming from the engine. I checked the radiator, and it was a little low, but not that bad, was this what was causing the boiling sound in your opinion? Because it kinda sounded like it was coming from underneath a valve cover, but its kind of hard to tell where a low pitched bubbling noise is coming from when under a truck hood.
Any info will be greatly appreciated as always! Thanks guys!
Old Jun 14, 2007 | 04:09 PM
amish77's Avatar
amish77
It shouldn't have gotten hot enough to boil the coolant in the engine from a short run like that. If there's air in the system then it can make a boiling sound. If the engine hisses when you start it up I'd say this is the problem. Otherwise I'd keep an eye on the temp gauge. If the heads aren't getting hot then you're fine.
Old Jun 14, 2007 | 08:57 PM
Titantis's Avatar
Titantis
Yeah, it only happened that one time, it has never done it again, and seems to run cooler now. Thanks. However it does sometimes hiss when I turn the engine off, from the drivers side, around the power steering.
Old Jun 15, 2007 | 07:55 AM
amish77's Avatar
amish77
Might just be pressure equalizing. I've heard a lot of engine hissing when they shut off, as long as you're not losing fluid you should be fine.
Bronkenstein
Apr 25, 2012 02:39 PM
walt590
Jul 28, 2011 05:58 PM
reddawg7
6.4L Power Stroke Diesel
Sep 5, 2007 05:05 PM
79'f150
Mar 18, 2005 10:48 PM
Seabeetough
16
Jul 27, 2003 08:32 PM
