fule composition code
Old May 23, 2007 | 12:59 PM
dullarrow's Avatar
dullarrow
Got a 2000 ranger with a 3.0 liter, a few weeks back it died on the highway, had it towed and the shop said it had water in the gas, they changed the fuel filter and cleaned the mass air flow sensor? It ran fine for a week or so and then died again, this time just for kicks when the tow arrived I tried to start it and it started right up and ran fine. Took it back to the shop and they said it was still the effects of the water, code was "fuel composition". So they sent me on my way again, this time it ran great for 4 days and died on Monday, towed it to a Ford dealer (I was out of town) and they said it was a "water getting into tbs connector" code so they cleaned the connector under the seat)? Still has the flex fuel code, but is running again. I afraid to drive the dang thing too far, think it's solved?
Old May 23, 2007 | 01:15 PM
pgw85706's Avatar
pgw85706
Have you refueled? How much fuel is left in the tank? Did either of the shops pour some water evaporator into the tank?
Welcome to FTE.
Old May 23, 2007 | 01:24 PM
dullarrow's Avatar
dullarrow
more info
shop 1 put some Isopropyl (sp?) in and when I refueled last time so did I.
thanks
Old May 23, 2007 | 01:25 PM
dullarrow's Avatar
dullarrow
currently has 3/4 tank, first 2 times is was faily low when it happened (1/4 tank) this time it was full
Old May 23, 2007 | 07:12 PM
dullarrow's Avatar
dullarrow
more info
Well after spending $450 at shop 2, it died again tonight on the way home. I was desperate to save on another towing bill so I unhooked the neg cable from the battery and waited 10 - 12 minutes, hooked it back up and it fired right up and got me home before the check engine light came back on, but it was still running fine when I got home. Any ideas would be most appreciated, I'm running out of cash, spent almost a grand on towing and "repairs" and it's the same as it was before.
please help
Old May 24, 2007 | 06:42 AM
Rockledge's Avatar
Rockledge
What code are getting? Is it P0176?
This is probably the TSB that the dealer is talking about: https://www.ford-trucks.com/forums/s...2&postcount=10
Old May 24, 2007 | 07:28 AM
dullarrow's Avatar
dullarrow
yes, that is the connection he worked on, however it did't fix the flooding problem, the truck still dies out from time to time.
Old May 24, 2007 | 07:36 AM
pgw85706's Avatar
pgw85706
Can you advise the specific code reported here?....."Still has the flex fuel code, but is running again".
Also is the CEL on now?....."got me home before the check engine light came back on,"? If so, is it possible for you to get the codes?
Old May 24, 2007 | 08:18 AM
dullarrow's Avatar
dullarrow
they did not give me the exact codes, shop 1 said it was a "fuel composition error" code?
Old May 24, 2007 | 10:25 AM
Rockledge's Avatar
Rockledge
The Ford fuel composition code is P0176.
If trouble code P0176 is not caused by a bad harness connector as per the TSB, then it usually points to a faulty flex fuel sensor, which unfortunately, aren't cheap.
The flex fuel sensor is mounted directly underneath your driver's seat on the left frame rail. It connects up to a wire harness that mounts to the frame rail on a plastic bracket.
Regarding DTC P0176, see:
https://www.ford-trucks.com/forums/2...d-ii-code.html
See in general: http://www.babcox.com/editorial/us/us020628.htm
P.S. You ought to spend the 100 bucks a year and get a Triple A premium membership. Stop getting whacked by the tow companies every time a problem arises.
Old May 24, 2007 | 10:29 PM
MazdaRangerGuy's Avatar
MazdaRangerGuy
I've seen a few of these trucks with that code set (hope mine never goes bad).. but I have yet to see one not run because of it. Are you sure the dying and the code is related? Was your check engine light on before it started dying?
Sometimes it's easy during diagnostics to assume the symptom is related to the code.. so you can easily get focused on that fact, when sometimes it can be something completely different...
Old May 25, 2007 | 05:20 AM
dullarrow's Avatar
dullarrow
the light came on as it started to miss, or chug, then it died, the guy at the shop said it was severly flooded. He changed the plugs, and oil (had fuel in it). He said something about having to turn off the fuel pume to keep if from flooding at first. I am trying to get it to do it again so I can see if the reset (unhooking the neg cable) was a fluke. thanks for all the info so far.... someone else suggested a fuel pump relay, where is that located on a 2000?
Old May 27, 2007 | 07:50 AM
dullarrow's Avatar
dullarrow
Any one know of a good source for a flex fuel sensor? Also, where is the fuel pump relay on the 2000 with a 3.0 liter.
thanks for all the info! What a great site, once I get this problem tackled I may give the door ajar switches a try.
Old May 27, 2007 | 08:16 AM
Rockledge's Avatar
Rockledge
I'd try searching eBay and the internet in general, I've seen the FFV sensors going for cheaper then what you'd pay at a dealer. Check out some local junkyards while you're at it.
As for the location of the relay, check your owner's manual. If you need one, you can get an online version (PDF) from here:
http://www.genuineservice.com/genuin...ault?page=Home
Door Ajar/Dome Light-Staying-On issues are usually solved with a couple of squirts of WD-40 in the door latches. See:
https://www.ford-trucks.com/forums/1...ome-light.html
Nobody39
Nov 25, 2015 03:26 PM
dcelrod
Sep 24, 2014 05:15 PM
bustedassranch
Jun 15, 2014 01:07 PM
Kb528
May 8, 2014 09:14 PM
Mustang302
Apr 15, 2014 08:24 AM
