explorer pinging
Old May 23, 2007 | 05:22 AM
Shovelhead 93's Avatar
Shovelhead 93
explorer pinging
I havw a 95 explorer,it has 302,000k on it just had trans rebuilt and I noticed the engine pinging under light load,it also has a miss when idling,time for plugs and wires or time for a rebuild?I was told the timing chain was on its way out.
Old May 23, 2007 | 07:52 AM
stuart1's Avatar
stuart1
wow, that's a few km's.
Try a minor tune first then make a judgement.
A compression test for starters.
Old May 23, 2007 | 09:44 AM
Mic_bug's Avatar
Mic_bug
you can temp. pull the shorting block to change the timing a few degrees to verify as well
Old May 23, 2007 | 10:10 AM
aquanaut20's Avatar
aquanaut20
Never seen a timing chain go bad in the X engine.
Ping is usually associated with running lean, check for vacuam leaks and clean the MAF.
Have you pulled any codes?
Do the plugs and wires, do not use Champion, I find NGK (P) and Motocraft(Px2) work best.
BTW, we have X engines with 335,000+k and 425,000k, never opened other than intake gaskets.
Old May 23, 2007 | 11:21 AM
MrSki's Avatar
MrSki
Best to change the O2 sensors first. Aquanaut might agree.
Old May 23, 2007 | 11:31 AM
aquanaut20's Avatar
aquanaut20
Best to test the O2, before replacing them. dont throw $$$ away.
Pull the codes (even if the MIL is off)
After you do the tune-up (get rid of missfire) then we can look at the other problems.
Old May 24, 2007 | 01:04 AM
MrSki's Avatar
MrSki
LOL...this site needs a bit more humor!
Old May 24, 2007 | 04:48 AM
Shovelhead 93
well thanx alot guysI will do plugs and wires and go from there,I get a random check engine light,how do I check the codes on this??
Old May 24, 2007 | 08:13 AM
aquanaut20's Avatar
aquanaut20
Since you unit is pre 96 (start of OBDII) you can follow the following proceedure,
http://fords.kilonet.org/ken00/EECIVQT.pdf
Old May 24, 2007 | 10:13 AM
quicklook2's Avatar
quicklook2
that was a good link aquanaut20.
Old May 24, 2007 | 06:14 PM
aquanaut20's Avatar
aquanaut20
When you are finished with your tune up and have pulled the codes for us, here is some more reading and test proceedure for your O2's.
http://www.mr2.com/TEXT/O2_Sensor.html
Note; 9 0f 10 that I have tested proved to be well within operating perameters, and the owners just wasted their hard earned cash.
Old May 24, 2007 | 09:16 PM
stuart1's Avatar
stuart1
That is the sad truth.
The codes will point to a system and the first thing people do is install a widget. Then bitch because it didn't work.
Old May 25, 2007 | 12:36 AM
LV Dan's Avatar
LV Dan
I had a mild ping under load that was difficult to diagnose. It slowly became worse. I tried everything including engine diagnosis, plugs and wires (the plugs showed signs of timing problems) and cleaning the mass air flow sensor. But it didn't help. The O2 sensors showed within range on the scanner.
I ended up changing the timing chain, tensioners and guides for the dreaded rattle (a separate noise made by my engine). The ping went away. I fiugre the slop in the time chain from the worn out guides was causing the pinging problem, too.
Also, I thought there was a TSB for a slip of the timing chain drive due to a key that can come out. But I can't find it now.
chicagodragon
Aug 30, 2011 08:06 PM
94 white
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jan 2, 2005 04:07 PM
biit55
Oct 9, 2004 07:41 PM
koalamazed
Aerostar
Aug 13, 2004 12:46 AM
dc10sean
Mar 28, 2001 05:29 PM
