Aerostar Ford Aerostar
pinging 4.0
Old Aug 3, 2004 | 12:47 AM
koalamazed's Avatar
koalamazed
Arrow pinging 4.0
ok. my 4.0 pings when i hit passing gear on the freeway.
someone suggested that it may be tranny fluid getting into the manifold or something.
but, when I pull my travel trailer I run super unleaded, and it does not ping. ever!
so, if the ping goes away with super unleaded gas... whats the real problem? I dont wanna buy super all the time!
p.s. my 3.0 pinged too, but I never tried putting super in it, so I dont know what that deal was!
Old Aug 3, 2004 | 06:02 PM
GoneFishen's Avatar
GoneFishen
By pinging, do you mean a knocking sound like the timing is too far advanced (pre-ignition?) Couple years ago my 4.0 did this, switched from regular to mid-grade gas, went away. Few months later started knocking again, had to go up to premium to stop it. Few more months later started knocking again, Stealership couldn't find anything wrong, they said drive it and don't worrry about it. I worried, had to use octane boost to stop the knocking.
Soon octane boost wouldn't stop the knocking. Took it to another mechanic, he couldn't find anything wrong, but pulled chip out from above the master brake cylinder (don't know what it's called) and that stopped the knocking. It also tubed my fuel economy. Took it to another stealership. They said the mass airflow sensor had to be replaced and the injectors serviced. $450 dollars later and the van is fixed, and never had another problem with it.
Hope this helps.
John
Old Aug 3, 2004 | 11:18 PM
biederboat's Avatar
biederboat
Many time the oxygen sensor (near the air filter with 4 security type torx screws) just needs to be cleaned with elelctrical cleaner spray. Go to a good hardware store and buy the type of drive you need, remove sensor, spray the "resistor" looking device and replace.
Good luck,
biederboat
Old Aug 4, 2004 | 12:32 AM
94 4liter's Avatar
94 4liter
My 94 ext did the exact same thing when I bought it last Nov. and from reading up on the older posts I pulled the MAF sensor and cleaned it REAL well with electrical contact spray (the tiny wires were coated black with dirt). Bingo, idled smoother, pulled stronger (by the Official Levi's Dyno ) AND stopped all the pinging even on the weak-tea 87 octane. I was pleased to say the least.
BTW...the MAF Torx screws are the security type, I bought a driver bit set from Pep Boys. A few older posts suggest grinding the protrusions down OR replacing those screws altogether with a common Phillips or Allen head.
Old Aug 7, 2004 | 10:14 PM
bear2x2's Avatar
bear2x2
I hope you replaced that tiny chip that so called mechanic pulled out. That is for setting your timing. When it is removed it takes your computor out of the ignition circuit so it is not advancing the timing so you can set it. If its left out your van will not advance the timing when accelerating and it will be running rich. Cleaning the MAF sensor is a good thing to do periodically. Also the oxygen sensor should be replaced at 60,000 miles.
Old Aug 12, 2004 | 06:51 PM
kf4zra's Avatar
kf4zra
so is it a bad thing that i still am running the original o2 sensor in my 93 4.0 with 177k mi? it hasnt thrown a code yet, and i am getting 18-20 mpg.
i just get a little knocking/pinging under moderate incline conditions.
Old Aug 13, 2004 | 12:46 AM
koalamazed's Avatar
koalamazed
just another detail....
mine seems to only ping under higher RPM conditions.
NOT like when I am accellerating onto the freeway. I can floor it while merging and get no pinging.
so, uder load, no ping, under high rev, pinging.
pidaster
Aug 30, 2011 06:43 PM
Milwaukee1979F150
Oct 4, 2010 12:17 PM
nothercrash
Sep 6, 2010 10:09 PM
loudford
Modular V8 (4.6L, 5.4L)
24
Jun 11, 2010 09:40 AM
Eric K
Modular V10 (6.8l)
126
Apr 20, 2008 12:35 AM
