Need Wire Pulling Help
Old May 22, 2007 | 09:09 PM
Bruker's Avatar
Bruker
Question Need Wire Pulling Help
I'm installing some low-voltage step lights in my brothers patio. The boxes are concreted in and they're connected with that blue flexible corrugated conduit. I'm now trying to get the wire through and I'm first pulling a string through the conduit by hooking a shop-vac up to one end and feeding a string through the other end. It's worked great for the first few boxes but now I'm struggling getting it through a long ~20' run that consist of about 5' of 1/2" corrugated to 10' of 1" solid PVC to another 5' of 1/2" corrugated. The shop-vac method is putting great vacuum on the run but I can't get the string to feed all the way through (it's getting hung up somewhere). The bends are too tight to run a fish tape through and wire gets hung up in the corrugated conduit. Any ideas?
Old May 22, 2007 | 09:36 PM
jake00's Avatar
jake00
put a small ball of string on the end?
Old May 22, 2007 | 09:38 PM
Torque1st's Avatar
Torque1st
Posting Legend
Tie the string to a cotton ball.
Old May 22, 2007 | 09:42 PM
bucks77ford's Avatar
bucks77ford
How many bends are there and are they 90 degrees? A fish tape should still work. It might be getting hung up on the connectors rather then the bends.
Old May 22, 2007 | 10:02 PM
Bdox's Avatar
Bdox
If all else fails, try pushing some piano wire or metal fishing leader wire through. Make a small loop in the end and tape it because a sharp end tends to catch on anything.
Old May 22, 2007 | 10:11 PM
conger's Avatar
conger
Try using a piece of plastic from a bag or something cut about a 3" piece. Ball it up and tie the string around it so it make kind of a ball on the end. Try the shop vac on that... make sure you got a good seal. If your still stuck, might be the coreline conduit came apart or got crushed. If you can't push a fishtape you might have some flattening or too many bends. You also might try pushing the fishtape with some wire lube. I hope this helps a bit. I'm an electrician and have had corelines (blue flex) crushed on 200' runs. Sometimes the only course is to cut the slab and repair the pipe. If you can figure out where the tape gets stuck, it might give you a clue as what the problem is. Hope this helps....
Old May 22, 2007 | 11:44 PM
Mil1ion's Avatar
Mil1ion
I was going to suggest tying it to a wedding ring..
Those tend to go through a ton of bumps in the road
Old May 23, 2007 | 02:12 PM
Bruker's Avatar
Bruker
Thumbs up
Success! I tried using a thinner string to pull through the conduit and it worked on the first try! I then retied the thicker wire pulling string to the thin stuff and pulled it through. Tomorrow I'll pull the wire through and all will be well.
Old May 23, 2007 | 02:26 PM
tcbofade's Avatar
tcbofade
BOOOOO!!!
Old May 24, 2007 | 07:14 PM
berkad's Avatar
berkad
tcbofade, well I have to guess the answer to you signature, with your post in mind , is NEITHER
Bwaa haaa haaaa
Racerguy
Jul 4, 2011 08:19 AM
scottie2hottie
29
Sep 7, 2008 04:14 PM
omni
16
Oct 11, 2007 08:54 AM
TN-W124 Diesel
Mar 25, 2006 12:17 PM
fred_79f250
33
Jun 18, 2005 01:29 PM
