I'm installing some low-voltage step lights in my brothers patio. The boxes are concreted in and they're connected with that blue flexible corrugated conduit. I'm now trying to get the wire through and I'm first pulling a string through the conduit by hooking a shop-vac up to one end and feeding a string through the other end. It's worked great for the first few boxes but now I'm struggling getting it through a long ~20' run that consist of about 5' of 1/2" corrugated to 10' of 1" solid PVC to another 5' of 1/2" corrugated. The shop-vac method is putting great vacuum on the run but I can't get the string to feed all the way through (it's getting hung up somewhere). The bends are too tight to run a fish tape through and wire gets hung up in the corrugated conduit. Any ideas?
If all else fails, try pushing some piano wire or metal fishing leader wire through. Make a small loop in the end and tape it because a sharp end tends to catch on anything.
Try using a piece of plastic from a bag or something cut about a 3" piece. Ball it up and tie the string around it so it make kind of a ball on the end. Try the shop vac on that... make sure you got a good seal. If your still stuck, might be the coreline conduit came apart or got crushed. If you can't push a fishtape you might have some flattening or too many bends. You also might try pushing the fishtape with some wire lube. I hope this helps a bit. I'm an electrician and have had corelines (blue flex) crushed on 200' runs. Sometimes the only course is to cut the slab and repair the pipe. If you can figure out where the tape gets stuck, it might give you a clue as what the problem is. Hope this helps....
Success! I tried using a thinner string to pull through the conduit and it worked on the first try! I then retied the thicker wire pulling string to the thin stuff and pulled it through. Tomorrow I'll pull the wire through and all will be well.
