Dexron 5 fluid
Old May 22, 2007 | 08:17 PM
fordracer08's Avatar
fordracer08
Dexron 5 fluid
I have a 91 F150 4X4 5.0 5 speed. I want to change the trans and transfer case fluids. The manual calls for Dexron 3 fluid. Can dexron 5 be used in this application. Has anyone used Dexron 5 in there trans or transfer case. Any opinions appreciated.Thanks.
Old May 22, 2007 | 09:25 PM
jroehl's Avatar
jroehl
Well, actually, you're looking at Mercon III vs. Mercon V. Dexron is, I believe, a *cough* Chevy *cough* standard. There's a bit of a debate about whether V does harm to III trannies or not, but Ford seems to have put out a TSB that V is now acceptable in all trannies that previously required III, and III is being discontinued.
Jason
Old May 23, 2007 | 06:23 AM
fordracer08
Dexron 5
OOPS. Yes I mean Mercon. I have read that Mercon 3 was being discontinued. Just wondered if anyone has delt with this issue. Thanks.
danlee
26
Mar 23, 2022 04:34 PM
potter573
Nov 11, 2012 10:18 AM
RGV10SD
Dec 1, 2008 09:07 PM
straightsixer
Apr 21, 2008 03:37 PM
ClatonK
Nov 12, 2005 01:30 PM
