I just had my E4OD rebuilt. The rebuilder recommends Synthetic Fluid. I had been using Dexron/Mercon in the past. I can't find Synthetic Dexron/Mercon.
DEXRON/MERCON are outdated, discontinued ratings. MERCON V has replaced MERCON. Mobil 1 synthetic ATF is VERY, VERY good fluid and has a MERCON V rating.
Should I replace the old ESP-M2C83-C automatic trans fluid that is in my Single Rail Four-Speed Overdrive with Mobil 1 synthetic ATF? If a Former Automatic Transmission Engineer says too, that would trump a transmission guy at a local shop? Mark Kovalsky,
Do you think that is Mobil 1 synthetic ATF is what I should replace the old stuff with???
That spec is for an 80 weight gear oil. ATF will KILL this transmission! Do NOT use ANY ATF, even synthetic, unless you just want to find out how fast you can kill the trans.
Synthetics or not synthetics only matters in how much money it costs to buy it. Synthetics can ALWAYS replace conventional fluids AS LONG AS THE RIGHT FLUID SPECIFICATION IS USED.
If you put a MERCON V synthetic in a C6 that requires Type F ATF that trans will fail in a VERY short time. On the other hand, if you put conventional MERCON V fluid in that same C6 it would also fail in a VERY short time. MERCON V is "slipperier" than Type F. Conventional MERCON V is EXACTLY as slippery as synthetic MERCON V.
Mileage is not a factor in the decision whether or not to use synthetics.
I went to my local auto store and bought the right stuff. The Pic I tried to post was a fluid with both Mercon and Dextron...I purchased Mercon only this time...now I have about 5 hours and $ 80 into this....instead of coming here and asking from the get go
I appreciate the responses , thank you...now I'm fighting the line going into the radiator...
Original, 1995....194,000 miles...plus I drove it from Key West to Clearwater and back last week for the races (SBI) which probably put a little strain on it
I meant that there is no mileage limit on an engine or trans where you can switch to synthetics. I've heard many people say that you should never switch if you have more than XXX miles or it will grenade. That's just not true.
I prefer synthetics when the vehicle is worked hard. If it is used as a commuter/grocery getter then I don't see any benefits from synthetics.
