Project engine cam-etc
Old May 26, 2007 | 05:23 PM
  #46
3Mike6's Avatar
3Mike6
Grr, I think it wasn't meant to be today..now it's hot and I'm giving up and cracking several cold ones.
Old May 27, 2007 | 12:53 PM
  #47
Skipped_link's Avatar
Skipped_link
I guess I'll give my take on the engine, first off the cam I offered is used, I would not have a problem buying a new set of lifters & running it, with that said, the summit cam that Mike has brought up is a good cam for what you guys want to do, I have run this cam in a 10:1 460 & it had good bottom end & a really strong mid range,I think that the engine needs to come apart before to much comitmant is made, Lets see whats in the bottom of that thing and go from there, if some one wants to send me a pic of the combustion chamber & the tops of the pistons I'll be able to give you a close estimate on compression,
Oh and Clint, the 49 probably makes 750 hp at 2500 rpm, under a full blast of throttle it is probably closer to 1500 hp
Old May 27, 2007 | 02:12 PM
  #48
3Mike6's Avatar
3Mike6
That's freaking awesome.
I'll try to borrow a camera this week for pic's, hope to pull the heads tomorrow after I get the engine steamed off.
Old May 27, 2007 | 03:05 PM
  #49
WillyB's Avatar
WillyB
I will come up when you are ready - I am curious, plus prefer to do the camera work myself!
Old May 27, 2007 | 03:27 PM
  #50
3Mike6's Avatar
3Mike6
I'll let ya know, but I just rememebered tomorrow is a holiday, so I'm not sure what will be open...I may have some other fittings to swap out...it's a 1/2inch quick disconnect, the orings inside went to hell and spray water all over the place.
Might have something off some old airlines out back that will work, I'll take a look when I go make a water change this afternoon.
