Project engine cam-etc
Old May 21, 2007 | 02:09 PM
  #31
AnOldDog's Avatar
AnOldDog
Yes, the radiator can be relocated to the bed. Some are concerned about building something other than a general purpose vehicle that could be used for hauling firewood and other normal activities. I'm in favor of relocation, but that is not everyone's opinion. It is not a decision that needs to be reached immediately.
Old May 21, 2007 | 02:11 PM
  #32
WillyB's Avatar
WillyB
Originally Posted by Nighteyez
Does the stock class allow the radiator to be moved to the bed?
See post number 20 of this thread.
Old May 21, 2007 | 02:30 PM
  #33
WillyB's Avatar
WillyB
This is all I have in the way of rules - they were the one's used at Rattlesnake Raceway in Fallon, Nevada.
If someone has a better set, please email them to me or post them here.
MUD BOG RULES
Revised 9/8/05
Entry fee: $30.00; Pit Opens: 3:00p.m; Tech Time: 3:30p.m; Qualifying Starts: 4:00p.m.
Each vehicle must take two qualifying runs. A 16-entrant ladder will be used for each division. A single elimination bracket will be used.
DIVISIONS:
STREET:
1. Any street driven vehicle with current registration & license.
2. D.O.T. approved street tires no larger than 33” as per the marking on the sidewall.
3. Must have factory engine for type of vehicle. (Ford to Ford, GM to GM, ect.)
4. Open headers allowed, under chassis type only.
5. 4, 6, & 8 cylinder engines will run together.
6. Must have single carb or fuel injection.
7. No nitrous, methanol, alcohol.
8. Turbos, or Superchargers, must be factory installed.
SUPER STREET
1. Any off road vehicle with current registration & license.
2. D.O.T. approved street tires no larger than 38” as per the marking on the sidewall.
3. Any engine vehicle combos allowed.
4. Single carb or fuel injection only
5. Open headers allowed; upright style allowed.
5. No nitrous, methanol, alcohol, turbo (except factory installed) or superchargers (except factory installed.)
UNLIMITED
1. Run what ya brung!!!
SAFETY EQUIPMENT
ALL vehicles must be equipped with seat belts. All drivers & passengers, if allowed, must wear seat belts. Open top vhicles must wear approved helmets during runs. Modified cab & open top vehicles must have a rollover protection 4-point cage, minimum. All batteries must be properly secured. Relocated batteries must be properly secured & enclosed. Fire suits are required on any supercharged (other than factory) vehicles or any vehicle using nitrous oxide, alcohol, or nitro fuel additives. All vehicles must have a 3” or larger clevis or 3/8” or bigger chain loop securely fastened to rear frame with easy access for vehicle recovery.
Old May 21, 2007 | 02:53 PM
  #34
WillyB's Avatar
WillyB
The single point that has driven this project all along is that the truck has to be registered and licensed. In California we have to meet the smog requirements in order to licenses it.
Therefor, we either run a non-modified smog legal stock setup, or build a smog-test exempt 1975 or older truck. That is why we picked the 72 - no title transfers needed, just a matter of paying the license fee to be legal to drive it on the streets.
Old May 21, 2007 | 03:53 PM
  #35
WillyB's Avatar
WillyB
Originally Posted by 3Mike6
OKay, . . . But hey. let's try to keep this thread on the engine, I want everyone to agree/disagree/yack about the build of the engine itself.
Sorry, I am guilty of the oldest sin in the book. Let's move all but the engine discussion to a new thread.
Old May 26, 2007 | 01:10 PM
  #36
AnOldDog's Avatar
AnOldDog
The 2166 should be the ticket, I've always like the Performer series of intakes, and we won't be overcammed to match.
The Edelbrock intake manifold is on it's way. That way Mike will have something to mate up to his Edelbrock 4BBL Carb. Mike should receive it sometime mid next week.
Chet
Old May 26, 2007 | 01:16 PM
  #37
3Mike6's Avatar
3Mike6
Good deal, I moved the steam cleaner in front of my shop yesterday, when the wife get's home I'm going to go get the engine and steam it off and get it prepped for tear down...PB Blaster, etc.
Old May 26, 2007 | 01:28 PM
  #38
AnOldDog's Avatar
AnOldDog
After the flow discussion, I realize that this won't add much. But it will look sweet!
Old May 26, 2007 | 02:05 PM
  #39
WillyB's Avatar
WillyB
What??? It is essential. We absolutely have to have an aftermarket manifold port matched to our heads - you are giving us an extra maybe 40 horses over the 2bbl it had!
There is a whole bunch of things that have to work well - leave any of them undone and the entire string is useless.
Clint
Old May 26, 2007 | 02:16 PM
  #40
3Mike6's Avatar
3Mike6
For sure the 4bbl would be needed, no doubt about it, it's good for at least 10hp/15ft/lbs over a stock cast iron 4bbl intake
Old May 26, 2007 | 02:54 PM
  #41
AnOldDog's Avatar
AnOldDog
AND, it's sweet looking bling! A win, win proposition.
BTW, I did a little simple math and this seems equivalent to a little over two hours labor. (not the $0.30/hr rate normal for hobby mechanics). No big deal. You guys are spending a bunch more wrench time than me.
Chet
Old May 26, 2007 | 03:24 PM
  #42
3Mike6's Avatar
3Mike6
I could bling it up some as well if I can find a deal on some glass pellets for my cabinet, they make some media blasting stuff now that almost puts a shine on aluminum castings.
PS....you make good money!
Old May 26, 2007 | 03:32 PM
  #43
3Mike6's Avatar
3Mike6
Well, heck...now I gotta go get some deisel to fill up the tank in the steam cleaner, least I have a good enough water hose to make things work
I don't understand it, I just put 3 gallons in 2 years ago....
Old May 26, 2007 | 04:39 PM
  #44
3Mike6's Avatar
3Mike6
Grrr...got diesel, now got a leak in the quick disconnect.
Wonder if it's an omen?
Old May 26, 2007 | 04:41 PM
  #45
nevrenufhp's Avatar
nevrenufhp
just means you need more things to do! Or, you'll appreciate it more after it's all fixed.
