Project engine cam-etc
Old May 20, 2007 | 01:37 PM
3Mike6's Avatar
3Mike6
Check this link to summit, I think it'd be fine, more lift might be better, but I'm not sure with the heads we have, if there would be any benefit.
http://store.summitracing.com/partde...1&autoview=sku
And this timing chain set:
http://store.summitracing.com/partde...0&autoview=sku
Probably this gasket set, might be an off-brand cheaper, but I like FelPro
http://store.summitracing.com/partde...5&autoview=sku
Chet (AnOld Dog) is going to send an intake down from Summit, I'll dontae the Edelbrock 750 I have, or...I have a Holley 750 dual feed, vac secondary
How's the plan?
Summit's other brand cam, I think may be too tame, as it runs out at 4K, I think it'd be a better can for trail riding, but for the bogs, the cam I listed would be better.
Old May 20, 2007 | 02:31 PM
nevrenufhp's Avatar
nevrenufhp
That looks to me like a nice all-around kam. I'd run it.
Old May 20, 2007 | 03:20 PM
AnOldDog's Avatar
AnOldDog
The numbers look pretty good. The valve lift is a little on the light side, but are other variables that may make up for it.
Run it. The price is certainly right.
Old May 20, 2007 | 03:30 PM
AnOldDog's Avatar
AnOldDog
As to the intake manifold, do we need EGR or not? I'm thinking that one of these two should fit the bill.
EDL-2166
http://store.summitracing.com/partdetail.asp?part=EDL%2D2166&autoview=sku
EDL-3766
http://store.summitracing.com/partdetail.asp?part=EDL%2D3766&autoview=sku
It was suggested that I keep an eye open on ebay or craig's list, but any savings would be lost if it needed repair work. They're cheap enough that we might as well pick one up new.
Old May 20, 2007 | 03:51 PM
3Mike6's Avatar
3Mike6
The 2166 should be the ticket, I've always like the Performer series of intakes, and we won't be overcammed to match.
I'll do a search locally on Ebay and CL...I know at the swapmeets we could save a few bucks as well, plus it's cool to wander around anyways
Old May 20, 2007 | 03:53 PM
WillyB's Avatar
WillyB
You guys are ahead of me - please ignore the email I just sent.
As to the cam, didn't Skip offer us a new one he had? Of course, the kit cost with a cam may be about the same as buying the lifters and other parts by themselves.
Also, if we are going to push a Ford V8 to 6K RPM and use a high-lift cam, maybe a hardened push rod would be a good investment?
Old May 20, 2007 | 03:57 PM
3Mike6's Avatar
3Mike6
Doesn't seem to be any deals on Ebay, looks liek on closed auctions, the 460 Performers go for about 140 or so, plus another 30 to ship, best case....CL might be a better alternative
Old May 20, 2007 | 04:02 PM
3Mike6's Avatar
3Mike6
Couple of things Clint, running a used flt tappet cam, just goes against everything I've ever done, and for 80 bucks getting new cam and lifters I think can put that to rest...Summit's quality is as good as Crane and Melling from what I know.
Also, Hardened push rods are not any stroger than what comes in an engine (comparing like same stuff) but are used for eith when you run guideplates or if the holes in the heads are used for PR guides...the "hardened" is a case hardening, like on gears and stuff, to minimize wear...there are strocger aftermarket push rods, but I don't think they'ed be needed, we're not going to run a super aggressive cam with high spring pressures, etc...we will have to get some decent springs through, I'm sure the originals have lost thier poop by now.
Old May 20, 2007 | 04:03 PM
3Mike6's Avatar
3Mike6
Oops, just re-read your message Clint....I though Skips cam was used, not new?
Anayway, I think it might bee too much for us anyways, I though the duration was in the 235-range?
If so, and we have dished pistons and can't easily get the CR up to build proper cylinder pressure, we'd have a problem just getting the thing to pull out of it's own way.
ANyways, once we know what we have, we might be able to make a better choice.
Anyone know where to get engine specs on our motor>? I/e CR, head volume, piston type?
Old May 20, 2007 | 05:10 PM
WillyB's Avatar
WillyB
I have some of that information out of a book "Ford Performance" by Pat Ganahl. It is not a very good book, and I would not recommend it to anyone. It does, however, give some general information. I will bring it then next time we get together.
Pistons are one of the differences between truck and car engines. Typically the trucks came with deep dish pistons, the cars with flat top pistons with deep eyebrows. Basically you have to look to see what you have.
Also, you said "The 2166 should be the ticket, I've always like the Performer series of intakes, and we won't be overcammed to match."
Did you mean "overcammed too much"? or that our cam will match the intake?
Old May 20, 2007 | 05:20 PM
WillyB's Avatar
WillyB
I see that Nighteyes has put his camper up for sale, stating that it just drinks too much gas. It seems to have a strong engine - perhaps we could offer to swap a FE or even an I6 for his engine? Give him better mileage and give us a spare engine.
Old May 20, 2007 | 05:29 PM
3Mike6's Avatar
3Mike6
What I meant was is that with the cam I listed up top, would be a good match for the RPM range of the Performer intake.
So....based on what you're saying abuot car vs. truck engines, IF we have dished pistons, then our CR will probably be low, only (inexpensive) option to get it up would be to mill the heads, but we may have to go to far then angle mill the intake, get's to be a pain....otherwise it'd be new pistons or different heads.
I'd say unless we see some serious failure in the engine, we stick with what we have and build around it with a matched setup to our projected CR, we may be better off (if CR is real low) to go with the smaller Summit grind cam, I'd rather have the engine run right at the widest RPM range possible.
The perfromer intake will suit either cam grind Summit makes for the 460.
Old May 20, 2007 | 05:33 PM
3Mike6's Avatar
3Mike6
Might be a lot of work for little return...wandering through Craigslist I've seen a few 460's in the 200-250 range, in fact saw one with the EFI on it and 126K miles for 400/OB), "hear it run"., and I was just looking through the Modesto list.
Besides, if ours looks okay, it'll easily take the 500-5500 RPM bursts a hundred yards at a time for a very long time. We'll get some insight from our new member (forget the screen name) that offered to assist with the tranny, to let us know what we can change to make it shift where we want and save the possibility of an over shift trying to do it manually.
Old May 20, 2007 | 05:44 PM
3Mike6's Avatar
3Mike6
EDL-2166
EDL-3766
Hey Chet,
Just got to thinking, I know that there are some "offshore" copies of the Performer intake for SBC and BBC's, I'll taker another look through EBAY and see if I can spot some for the 460.
Old May 20, 2007 | 05:45 PM
AnOldDog's Avatar
AnOldDog
I was chatting with my son about this. He's done his share of mud drags in Iowa and he offered a couple of suggestions that seem to make sense.
1. Move the radiator to the bed of the truck, otherwise it gets clogged up really quick and starts overheating.
2. Block off the grill so mud doesn't cake in around the engine.
3. Fab up something like a skid plate to keep mud from piling up around the front axle and engine compartment.
4. Have a spare air cleaner assembly for a quick swap between races. You can clean the other one up between runs.
