Changed Plugs today........
Old May 18, 2007 | 07:12 PM
Black01Edge's Avatar
Black01Edge
Talking Changed Plugs today........
Well finally broke down and changed the spark plugs and wires in my 2001 Edge 4.0 and OMG even taking the passenger front tire off and going in from underneath these plugs had to be the worst set up i have had to change in my life.....Even worse than my v6 Fiero from years ago!!!!.Looking at the plugs now i can see why my truck is getting such semi crappy mileage....Why does Ford recommend such a long time before changing plugs my truck just rolled 80,000 miles on it and i can imagine if i waited till the 100,000 mile mark what they would look like. Got a set of motorcraft iridium plugs,Ford and Oreilys say the platinums have been superceeded so this is what they recommended and a new set of motorcraft wires and a fuel filter,and a fresh tank of 91 octane shell gas and 3.45 a gallon and reset my superchips tuner at its 91 octane setting and after 4 hours work WOW!!!!! The little truck runs like it has zero miles on it and with all the other mods i have done to it i did a little driveing around and think this might help the mpg situation alot if i can keep my foot out of it.
have a good week end all
regards
Steve a
Old May 18, 2007 | 07:40 PM
Rockledge's Avatar
Rockledge
Good job. A tuneup always brings out the best in our Rangers.
Old May 20, 2007 | 01:11 PM
Pablo-UA's Avatar
Pablo-UA
First time i did it it was terrible.... I was dirty like a pig.
Old May 20, 2007 | 10:30 PM
jimdandy's Avatar
jimdandy
How much of a power increase do you get from running 91 octane and a tuner??? jd
Old Jun 8, 2007 | 08:37 AM
sjrogers's Avatar
sjrogers
I need to change the plugs on my '02 Ranger 4.0 I have changed the drivers side easy, but haven't decided how to change the passenger side. Thought the inner fender needed to come out and maybe the tire. Any suggestions. I'm putting Bosch plugs in.
Steve
'02 Ranger
'02 Explorer
Old Jun 8, 2007 | 09:10 AM
quicklook2's Avatar
quicklook2
bosch plugs suck.
use motorcraft or you will be doing them again.
the last plug on pass side is accessed through the well well.
Old Jun 8, 2007 | 09:23 AM
rubydist's Avatar
rubydist
The Bamachips Xcal2 w/ 91 is 15-20 hp and similar torque increase documented on the dyno over stock.
I also have heard nothing but horror stories about Bosch plugs in the 4.0, so I do not recommend them. Motorcraft, Autolite, and NGK have all worked well for me.
Old Jun 8, 2007 | 11:37 AM
quicklook2's Avatar
quicklook2
in any ford bosch platinums of any kind are the worst investment and a rip off to boot.
they were crap in my 87 vette also.
Old Jun 8, 2007 | 10:08 PM
sjrogers's Avatar
sjrogers
What does everyone recommend? And what should I gap the plug at? The .065 on some of the plugs seems like alot.
Steve
Old Jun 9, 2007 | 05:47 AM
wendell borror's Avatar
wendell borror
Theres motorcraft, or you could allways try motorcraft and then theres motorcraft. Of course autolite will also work as well. I would need to check my owners manual for proper gap.
Old Jun 9, 2007 | 09:55 AM
quicklook2's Avatar
quicklook2
or the sticker under the hood for the proper gap.
Old Jun 9, 2007 | 11:42 AM
rubydist's Avatar
rubydist
The sohc engine has been spec'd at anywhere from .054 to .065 depending on year, etc. When I changed mine, some were as high as .077 and I saw no change in performance or mileage w/ the new plugs, so the electrical system really does have the ability to fire those 'huge' gaps.
Old Jun 9, 2007 | 06:05 PM
wendell borror
.077, are those spark plugs or flame throwers??????????
