18k power module
Old May 18, 2007 | 11:16 AM
wmiller's Avatar
wmiller
18k power module
Just bought 18k Power module for my 97' F-250. Any sugestions on installing and using it?
Old May 18, 2007 | 01:15 PM
tjbeggs's Avatar
tjbeggs
My suggestion. Return it and build you own! you can build one not quite as fancy for about $5 tops. $10 if you need to buy wire strippers.. Install should be the same as a 10k mod here
http://www.forgotton.net/mods/index.html
as far as using turn it up (actually down, less resistance is more power)as far as you can with out hating your idle and run it!
Old May 18, 2007 | 01:48 PM
Neal 97 250's Avatar
Neal 97 250
Would it be possible to do a 12K or 15 K or 18 K mod the same way the the 10K is done? If so, Is it safe? It would be cheap but I imagine we would have to watch EGT's the more we go. Possibly even wire them in parallel on the same leads and put a switch on each leg just to do some testing.
Krazy thought of mine.
Old May 18, 2007 | 01:52 PM
skittlejr's Avatar
skittlejr
i have a switch lying around with all kinds of posts on it. i was thinking of doing that kinda like off, hi and lo. i'll wait till i get the pyro gauge first though.
Old May 18, 2007 | 02:42 PM
tjbeggs's Avatar
tjbeggs
The 18k is variable but the same thing can be done with any variable resistor. The lower the resistance value the more change. So a 5.4k mod makes more change than the 10k but the 5.4k also makes for a rougher idle.
Old May 18, 2007 | 02:47 PM
Neal 97 250
So with the lower the # such as 5.4K - 10K the more smoke and power but the higher the # such as 10K - 18K the less smoke and power but smoother idle?
How far can you go, as long as it will idle, can you go before you hurt something. My guess would be limitless or until it quits running. Am I right?
Old May 18, 2007 | 03:07 PM
tjbeggs's Avatar
tjbeggs
Now that I think of this maybe I am wrong. Less resistance meaning more power would mean you have the most power when the 10k mod isn't in there! Now I have confused myself! I think the lowest I have heard of people going with good results is 5.4k. I hope somebody who has not confused themselves chimes in here!
Old May 18, 2007 | 03:15 PM
Neal 97 250
Just brainstorming... with factory it fires every 20,000th of a second or is it FOR 20,000 of a second and the 10K mod essentially doubles that which means @&#&%%^*$#&^*^%.
Now I am confused.
Old May 18, 2007 | 06:10 PM
skittlejr's Avatar
skittlejr
it doesn't change the timing, just the pressure at which the fuel is injected. the pcm still controlles the solenoids on the injectors. the 10k does the opposite of the limp mode. the limp mode defaults the pressure down to i don't know what exactly. disclaimer-i know all this from medium duty CAT engines which use the exact same technology. there may be minute details of difference between them, like injector size and the currents and pressures used. the hpop and ipr are the same. actually CAT allowed international to use this technology and sort of "field test" it for them so they could see it did, so i was told by a guy who's worked for CAT forever.
Old Jun 5, 2007 | 09:59 AM
wmiller's Avatar
wmiller
After runnin the 18k for a week or 2 I love it. Big diffrence in torque adn power pulling and at high way speed. I like the fact that it doesn't effect my idle at all like the 10 k will. My fuel milage went from mid 14s to 16-17mpg
Old Jun 5, 2007 | 10:04 AM
tjbeggs's Avatar
tjbeggs
wow thats a pretty good report. Thanks for the feedback on it.
Old Jun 5, 2007 | 12:49 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question
Yeap thats are good news. Where did you buy it?, was easy to install? The cost?
Old Jun 6, 2007 | 09:47 AM
wmiller's Avatar
wmiller
I got in on ebay for I think $40. Difuser makes it. Took about an 1/2 hr to install
Old Jun 6, 2007 | 01:20 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Thumbs up gracie
okey dokey, thanks for the info.
THEDON117
Jan 18, 2009 12:27 AM
HH60FE
Jul 13, 2008 08:31 PM
viperbluelx
Jan 11, 2008 09:43 AM
whitesdford
Mar 25, 2006 07:05 PM
wayfastwhitey
Jun 9, 2005 07:02 PM
