bed replacement/removal
Old May 16, 2007 | 04:29 PM
davefordforum's Avatar
davefordforum
Does anyone know what is involved in replacing the bed of a ranger? I looked under, and it looks like the gas tank is supported from the frame supports (does it have to be removed?). Does the bed simply unbolt from the frame. Beside disconnecting the rear lights, and the wire harness, is there anything else?? I have a 2002 ranger, supercab, flareside.
Thanks.
Old May 16, 2007 | 04:43 PM
fflintstone's Avatar
fflintstone
As far as i know, 6 bolts, gas tube mount, what you mentioned and two guys can easily lift it. Easier than dropping the gas tank. Lots of guys pull the bed to do the fuel sender/pump.
fred
Old May 16, 2007 | 05:30 PM
davefordforum
Thanks for the reply. When you say "gas tube mount", are you talking about the 3 bolts when you open the "filler flap", or is there an actual mount that holts the tank in place.
Thanks
Old May 16, 2007 | 06:52 PM
ranger1999 Bob's Avatar
ranger1999 Bob
it means the screws around the gas flange or filler flap once they are removed it should be clear to pull the six bolts out and lift the bed up
Old May 16, 2007 | 07:39 PM
fflintstone
davefordforum. Forgot to welcome you to FTE. You should like this site and get plenty of usefull info. You'll love it with the bed off. You'll see how accessible the gas tank is and you'll be able to do all kinds of maintenance to fuel line, paint the frame, power hose everything etc. Spring change is especially easy.
Good luck
Fred
Old May 17, 2007 | 03:50 PM
davefordforum
Thumbs up
Thanks for the help. I will try to change it next weekend, hope it's as easy as it sounds.
Old May 18, 2007 | 12:07 AM
Benaghetto's Avatar
Benaghetto
What is your goal with the removal of the bed of your truck? Is it the fuel pump or something else?
Old May 18, 2007 | 07:40 AM
RedBoat's Avatar
RedBoat
Rather Be Floatin
Dave, Unplug the connector going to the rear taillights too. It is one connector usually located right above the rear bumper halfway between the center of the bumper and the left(drivers side) fenderwell. Piece of cake job, much easier than it sounds, had mine removed in under 10 mins.
Old May 18, 2007 | 03:01 PM
davefordforum
I backed into something, and crunched one side of the quarter panel at the top corner; broke the tail light and bent the bracket that holds the tailgate, and broke the corner of one quarter panel. I went to the wreckers to buy a quarter panel and they wanted to sell me the whole box, and the price that they want for the whole box is reasonable; so I thought that I might as well replace the whole box since I couldn't straighten the tailgate bracket quite straight. The box that the wreckers has is the correct color, but the decals are for a 4X4, and i have a edge, 2WD.
Old May 18, 2007 | 03:04 PM
Benaghetto's Avatar
Benaghetto
Right on bud. Decals remove and apply easy. I know stuff happens and if the price is reasonable go for it. You could probably sell the inside shell of the bed and the other quarter to recoup some of the cost. You could actually hang your original good quarter on the new bed so you only have to worry about the one being different!! Food for thought.
Diddy
Paint & Bodywork
Apr 26, 2014 07:33 PM
fyreduck1921
Aug 6, 2013 07:08 PM
redbug
Oct 22, 2011 12:55 AM
griz4718
Dec 31, 2003 04:30 PM
boomer99
Jul 11, 2001 04:55 PM
