Gear Indicator mounting position
Old May 14, 2007 | 07:43 PM
vader17's Avatar
vader17
I pulled apart my dash to see if my speedo cable was connected (it was) and found out why my gear selector was not working in the dash. The cable is not attached to anything. can anyone tell me where I attach this to on the column. thank you
I have a 1989 F250 4x4 with a diesel 7.3 btw if that helps
Old May 15, 2007 | 10:25 AM
vader17's Avatar
vader17
Any thoughts on this?
Old May 15, 2007 | 01:21 PM
Lazy K's Avatar
Lazy K
I replaced the gear shift indicator on my `87F250 about a year ago. As I remember the little cable runs down from the dash and the outer piece ends with a small plastic plate that attaches to the outer steering column tube with a single screw. The inner cable ends in a loop which fits over a "spud" on the gear shift lever mount. To get at the dash you would have had to remove the cylindrical plastic trim piece over the steering column just below the dash, the fixings for the indicator cable are under this.
Old May 15, 2007 | 03:50 PM
vader17's Avatar
vader17
Hmmm, i had it kind of mounted like this. I found one screw whole that was under that plastic sleeve. I put a screw into it and tried shifting but it didnt really do anything. I will have to find a picture of this somewhere I think. I think im losing something in the translation.
Thanks for the help though!
80F250cust
1997 - 2003 F150
Nov 11, 2011 03:21 AM
jack wamp
Oct 31, 2011 12:05 PM
Daviddc114
Jul 30, 2009 10:49 AM
Dennis Krumenauer
Oct 25, 2008 09:17 AM
Yogis1097
Jul 19, 2006 06:38 PM
