My speedometer isn't working?
Old Oct 28, 2011 | 10:01 AM
jack wamp's Avatar
jack wamp
So my speedometer doesn't work. So i followed this cable that went to my dash and goes back to my transmission. I took a bolt out and attached to the end of the cable was a red plastic gear looking like thing with threads on it ,and it was all chewed up looking. I was wondering if anyone knew what that was called or were to get a new one.
and sorry i forgot to say its a 84 ford f250 4speed 4x4
Thanks
Old Oct 28, 2011 | 12:26 PM
lavatan's Avatar
lavatan
Hello Jack,
That is called a speedometer gear and they can be found pretty much anywhere. You should be able to find what you need on eBay:
ford speedometer gear | eBay
Edit: Mine was chewed up as well. You may want to consider getting a new speedometer cable as well. They're rather inexpensive and easy to replace. I believe the red gear is a 16 toothed gear.
Old Oct 28, 2011 | 09:57 PM
84-6.9L's Avatar
84-6.9L
It should give a tooth count on the bottom of the gear. And there is LH and RH rotations so make sure the teeth are piched the correct way.
Old Oct 31, 2011 | 10:41 AM
jack wamp's Avatar
jack wamp
Alright man thanks!
Old Oct 31, 2011 | 11:11 AM
84-6.9L's Avatar
84-6.9L
If you have 3.54 gears you are looking for the wine colored 16T driven gear, stick your finger in the hole in the t-case and make sure your 7T drive gear isnt chewed to s@#$.
Old Oct 31, 2011 | 12:05 PM
jack wamp's Avatar
jack wamp
Allright man thanks for the the help
93w124
Oct 4, 2020 05:59 AM
KsHighboy
Jan 26, 2017 08:23 PM
my996duc1
Sep 22, 2014 01:42 PM
hugger94
Jan 6, 2010 03:38 PM
onemanchan82
Jun 13, 2003 08:04 AM
