Tranny Fluid Question?!?!?
Old May 13, 2007 | 06:12 PM
ckal704's Avatar
ckal704
Question Tranny Fluid Question?!?!?
Changing fluid in the ZF5 tranny.......
Got the Royal Purple Synchromax fluid, but am confused a little about capacity?
OM says 3.5 qt. for the tranny and transfer case, but are they attached in a manner that allows them to share fluid?
I see another drain on the transfer case, but don't know where to dump fresh lube in if they are not connected. Had planed to simply pour oil in through the top of the shifter box as I can get in there by just gently pulling the lower rubber boot aside.
Looking for an answer ASAP as i just started this job tonight after spending the day with the wife and kids at a ball game for Mother's day (her request!).
I would definitely like to finish before dark.
Thanks gang!!!
Old May 13, 2007 | 09:23 PM
barebackjake's Avatar
barebackjake
its 3.5 qts for each unit. theres a seal between the two. i pour 4 in from the top and call it good.
and to pour it in from the top you have to pull the shifter out theres 4bolts that hold it in.
Old May 14, 2007 | 05:40 AM
ckal704's Avatar
ckal704
Thanks bbjake-
got it done last night after all. At first I didn't see the fill hole for the transfer case.
Marvo
Oct 27, 2013 05:01 PM
timbersteel
Aug 26, 2013 12:56 PM
Teager
Jan 10, 2013 07:09 PM
mycam8u2
Dec 13, 2007 08:24 AM
blownbronco
Jan 3, 2003 11:29 PM
