turn signal problem
Old May 12, 2007 | 10:35 PM
jcab's Avatar
jcab
turn signal problem
I don't know if it's related, but my overdrive light comes on intermitently, and right hand turn signal won't work sometimes. I can get it to work if I use the left turn signal then immediately use the right one. Something is wearing out in there. Anyone have the same problem? Thanks Jcab
Old May 12, 2007 | 10:43 PM
bigbadwolfe's Avatar
bigbadwolfe
sounds like the multfunction switch (the malfunction switch)
Old May 12, 2007 | 10:56 PM
Freakazoid!'s Avatar
Freakazoid!
I have similar issues, I am just waiting to find time to fix it.
Old May 13, 2007 | 10:08 AM
jcab's Avatar
jcab
Malfunction Switch?
SO WHAT THE BLEEP IS A MALFUNCTION SWITCH, IF THEIR'S SUCH A THING????? JCAB
Old May 13, 2007 | 10:30 AM
bigbadwolfe
it is called the multifunction switch i was making a joke with the malfunction because thats what it does but anyway that is your signal switch your wipers and your hi beams
Old May 13, 2007 | 11:12 AM
jcab's Avatar
jcab
how to do it?
so how difficult is it to do? Thanks Jcab
Old May 13, 2007 | 11:15 AM
10bands's Avatar
10bands
Good info here.
http://www.dzljim.com/Ford/mfswitch.htm
Old May 13, 2007 | 03:48 PM
skittlejr's Avatar
skittlejr
not real hard to replace. a little patience helps. i took mine off about a month ago to troubleshoot no turnsignals, ended up being just the flasher module. well, now my high beams are not working, so looks like i am taking all that plastic off again.
Old May 13, 2007 | 03:51 PM
skittlejr's Avatar
skittlejr
i just checked that link above, u definitely do NOT need to remove the steering to replace the multifunction switch.
Old May 13, 2007 | 05:55 PM
jcab's Avatar
jcab
Thanks for all the replies, would this switch have something to do with the overdrive light coming on and off by itself? Thanks Jcab
Old May 13, 2007 | 11:05 PM
bigbadwolfe
i dont think so that sounds like a trans issue
Old May 14, 2007 | 06:01 AM
Cuda_jim's Avatar
Cuda_jim
I totally agree, no need to remove the steering wheel to replace the multi-function switch. I would replace the switch 1st then tackle the flashing OD light. It may go away with a new switch, I had it happen!
jcab
May 19, 2008 02:14 AM
jcab
May 5, 2007 11:33 AM
jcab
Jun 7, 2006 08:56 PM
jcab
Jun 6, 2006 12:38 AM
jcab
Aug 21, 2005 06:29 PM
